Finely Started, KZ1300 INTERCEPTOR "Pictures as available"
  • otakar
  • otakar's Avatar Topic Author
07 Jan 2007 15:07
#104002
After quite a few years, just sitting in limbo, I finaly started work on my KZ1300A1. I want to do about a 90% rework on this bike with some high performance goodies. I rebuilt the engine at about 12000 miles because of a bad lower con-rod bearing which destroyed the crankshaft and #6 rod. I believe that I can leave the crank case intact and just rework the top end. I have 3 sets of heads and cylinders for the engine to work with, so I do not have to worry about screwups. I plan on sending out the cams to have them hard welded and reground with a bit more UMF I plan on punching out the jugs to somewhere betewwn 1400 and 1500, and ofcorse a new paint job. I am going to install a cut down 1985GPz fairing to the bars and not to the frame. I will try to post pictures as I go along. I would like to have this project finished before the end of the next riding season. Wish me luck.
Otto Kudrna
Post edited by: otakar, at: 2007/01/17 12:27
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • neilage66
  • neilage66's Avatar
Re: Finely Started, KZ1300 INTERCEPTOR
07 Jan 2007 18:20
#104039
Sometimes getting started is harder than finishing...unless you're Wireman! Good luck Otto. :)
Keep us posted.
Post edited by: neilage66, at: 2007/01/07 21:21
  • kzwolfsr
  • kzwolfsr's Avatar
08 Jan 2007 07:16
#104151
Doesn't the 1300 have 6 cylinders? If so good look on that! It could be the biggest displacement Kz I really know of.
Original man of the Caribbean
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
08 Jan 2007 07:35
#104154
Good luck Otto...I am sure we would all like to see the progress..take picture:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • StreetfighterKz
  • StreetfighterKz's Avatar
09 Jan 2007 13:48
#104506
To help you on your way a little bit of info I've picked up thru the years....use Kz650 pistons for overbore sizes. Noone makes a "piston kit" but supposedly Kz650 pistons work, and you'll have a couple spares if you buy to complete sets. Also, go get a cam chain tensioner from a 90-01 ZX11C/D model. Their stock tensioner is WAYYY better than a stock 1300 tensioner. And somewhere there is a CBX site that sells a set of Accel coils (three coils and necessary hardware) that you can get for decent $$. You will probably also want to get a small electric fuel pump from another model of motorcycle and install it. That will help cure some cold start and fuel starvation problems.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • otakar
09 Jan 2007 20:38
#104607
Well I did some math. I was counting on using Wisco 2mm oversize KZ650 pistens which would bring it to about a 1390. This would add about 15HP with the increased compression and I can keep the stock sleaves with amout 60thou left in the scirts. with the work and parts this 15HP would cost about a Grand. If i decide to go with the oversize CB750 Pistens it would take the engine to about a 1430 and add about another 7HP over the previous. However I would have to get custom sleeves which would be another $560 and have to deal with boaring out the lower part of the water jaket and inlarging the O ring pockets. This total would be another additional Grand. I do not think that 7HP is worth a Grand when I can get a set of potent cams for about $650 and get about another 17HP out of those. And if push comes to shove, I made a real nice Nitrometan injection system which would add a nice punch in a pinch. I think that this math makes a lot more sense,(and less Dolars).
Otto
Post edited by: otakar, at: 2007/01/09 23:39
Post edited by: otakar, at: 2007/01/09 23:40
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
13 Jan 2007 14:26
#105451
Here are the first pictures. I have finaly cut down a LATE GPz Fairing to fit the bars, and have just enough tank clearance. I plan on doing some glas work on it to fill some space in front of the bars and make a small spoiler at the bottem. Any IDEAS are welcome!
Post edited by: otakar, at: 2007/01/13 17:39
Post edited by: otakar, at: 2007/01/13 17:43
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
13 Jan 2007 14:39
#105455
Here is #2 The Bars are a set of stock Z1-R bars, and I think I will put a set of lower ones on yet.
Post edited by: otakar, at: 2007/01/13 17:42
Post edited by: otakar, at: 2007/01/13 17:44
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
13 Jan 2007 14:40
#105457
Here is #3 I do not plan on useing the full size wind sheald. I plan on Cutting it down also. I also plan on useing the Fairing mounted mirors and turn signals.
Post edited by: otakar, at: 2007/01/13 17:46
Post edited by: otakar, at: 2007/01/13 18:13
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
14 Jan 2007 09:24
#105559
With a bit of reaserch and reading I have decided on the Dynatech DC1-2 coils for this project. They are a 3 Ohm coil and will work well on any Kaw. They are also a very small package and should fit in the existing space.
Post edited by: otakar, at: 2007/01/14 12:25
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
17 Jan 2007 06:58 - 09 Dec 2010 07:10
#106255
I have made the decision to build TWO complete motors for this bike. One I will build with the Wisco custom pistens to make a 1390 and the other with 66mm KZ750 pistens to make a 1502. I have all the parts necessary to do this job, with the exeption of the new custom liners for the 1500 project, which should cost about $100 each. I have been on the web looking for parts to doo these jobs, since my last post and have been very lucky. I have also done some more work on the fairing, and some of the other body parts. I will take pictures on friday and post them.
Post edited by: otakar, at: 2007/01/17 10:00
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 09 Dec 2010 07:10 by otakar.
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
17 Jan 2007 10:12
#106309
:blink:
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
