Sorta new, but now I have a bike.
  • tommyp76
  • tommyp76's Avatar Topic Author
Re: Sorta new, but now I have a bike.
10 Dec 2006 19:20
#98887
pumps wrote:
my buddy who is a bike mechanic
I would think he might be a good budy to have!:woohoo:
Be SURE to buy him something good for Christmas..preferably some kind of tool he needs...to work on KZs!:woohoo:
Oh he's getting paid, well sort of. I trade him bike work for computer work so it works out well for both of us. ;)
1978 KZ650B
  • tommyp76
27 Dec 2006 13:02
#102036
Small update.
Just got about $200 worth of parts from fleabay and z1. New headlight
New spark plug boots
New fork seals
Carb rebuild kits
Used airbox (missing one boot and attachment brackets)
New brake pads
New throttle cables
Used chain guard
I'm going to take the day off on 1/2/07 and rebuild the carbs and start on the forks. Also I need to get the airbox in so that I can make sure I have enough clearance for the rear master cylinder.
Tom
1978 KZ650B
  • pumps
  • pumps's Avatar
27 Dec 2006 18:50
#102111
Keep us posted on how you're doing!;)
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
  • kzwolfsr
  • kzwolfsr's Avatar
31 Dec 2006 17:07
#102703
My disk on my 78 SR are drilled but I dont know if they were switched, but I think thats how mine came Pumps.
Original man of the Caribbean
  • pumps
  • pumps's Avatar
31 Dec 2006 18:14
#102707
kzwolfsr, My front rotor is drilled. I have seen ones on 78s drilled but have wondered if they were not oem.If you look on this page in the first section in the pictures none of the 78s have drilled rotors.It also says that in 79' the letters on the tank became all large like "KAWASAKI" but mine are "Kawasaki" like it shows in several pics so I dunno.
Post edited by: pumps, at: 2006/12/31 21:15
1977 Yamaha XS650
2000 Kaw W650
  • kzwolfsr
  • kzwolfsr's Avatar
31 Dec 2006 20:23
#102716
Yep I wouldnt bother to get brain fart on it. I suspect that as the year 78 was going out things were still changing over, like in the clymer manual they say the manufacturers in 1979 started putting in accelerator pumps on the carburetor to improve performance, so I am guessing I have a late 78 bike, which is pretty special
  • tommyp76
05 Jan 2007 11:13
#103543
Sorta funny but not really story.
So I was rebuilding the carbs on Tuesday of this week. Everything was going good as I moved to carb #2. As I started to remove a jet a piece of it snapped off and hit me in the left eye :S It didn't really hurt so I went on and finished up rebuilding them. Later that evening my eye started to bother me so I took out my contacts and noticed that it was cut. The night was horrible (constant watering and burning feeling). So I had my wife double check to make sure nothing was in my eye, of course she found nothing. So the next day I schedule and appt with the Eye Doc. She proceeds to tell me how lucky I was and that my contact saved my eye. Apparently I cut my cornea over 60% of the way through and if I hadn't had my contacts in I would probably have lost my eye.
So how's that for a routine carb rebuild. :blink:
1978 KZ650B
  • pumps
  • pumps's Avatar
05 Jan 2007 13:33
#103562
I ALWAYS read that you should wear safety glasses when rebuilding carbs but I always thought of it when using cleaner, not for pieces coming off! Thanks for sharing. Maybe i will be more careful after hearing this.
1977 Yamaha XS650
2000 Kaw W650
  • tommyp76
02 Mar 2007 12:17
#116762
She's almost ready for the road.
Last week I got the new turn signals on and wired up. Got a stock airbox put in and the carbs dialed in. Replaced the fork seals and changed out the oil. Changed the engine oil/filter. Changed out the rear shocks. Fixed the starter button. Installed the new grips and throttle cables.
Really the only things left are to get side covers painted and put on, get a new front tire, and get the rear master cylinder bracket that I made welded on and finish up those brakes.
1978 KZ650B
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
02 Mar 2007 13:17
#116772
It's the other way around. '78 and BEFORE have the all caps: KAWASAKI. '79 and after have Kawasaki.
Same with drilled discs, they started in '79, although the SR (D) model started some things before the B&C models.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • tommyp76
08 Mar 2007 08:47
#118376
So the crankcase breather hose that connects to the airbox is bad and I can't seem to find anyone that has one. Does anyone have a suggestion for a workaround/replacement?
Thanks in advance
1978 KZ650B
  • mariozappa
  • mariozappa's Avatar
08 Mar 2007 09:41
#118384
I might have an extra one, I'll have a look tonight.
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
