building a new wiring harness
  • Nessism
  • Nessism's Avatar
  • Away
Re: wiring-harness/loom
24 Oct 2025 07:21
#918344
thank you for the input Nessism -
what ship are you referring to?
Last time I tested them, the RR and stator are functional, although I can test them again.  The harness is very deteriorated.
I was asking what type of wire is recommended to build the loom with.  I was considering Raychem spec 55.  16 gauge seems the size.  store.emhmotorsports.com/raychem-spec-55-wire-single-core/
The current loom uses multi core - is this single core acceptable for a motorcycle application?  I understand you lose some flexibility.
If the main goal was fixing the charging system, you don't need to rebuild the main vehicle harness for that.  In fact, as mentioned, there is only one wire in the charging system that needs to touch the main loom, the power output wire.  Based on your photo, though, it seems that you made the decision to rebuild the entire harness.  That's the ship that sailed.
The following user(s) said Thank You: Injected
  • H1Vindicator
  • H1Vindicator's Avatar
Re: building a new wiring harness
25 Oct 2025 08:20 - 25 Oct 2025 08:28
#918364
vintageconnections has wire. made in USA. z1enterprises also has wire. made in china? don't know. could be Taiwan. possibly k&s. if K&L then made in Japan.  cycleterminals has connectors but no wire. afaik. for building a wire harness. if not already owned, be sure to get good tools. worth the cost.
Last edit: 25 Oct 2025 08:28 by H1Vindicator.
The following user(s) said Thank You: newt14
  • Nessism
  • Nessism's Avatar
  • Away
25 Oct 2025 08:24
#918365
79' KZ650 B3
I am looking to build a new wiring harness.  Any recommendations on the type of wire to use?  The most reliable robust option available.
-Rusty
Most reliable and robust?  Get MIL spec wire from Digikey or Mouser.  Teflon coated.
  • Injected
  • Injected's Avatar
25 Oct 2025 10:32 - 25 Oct 2025 10:33
#918367
I would go a bit oversize on the wire gauge compared with stock, one gauge up and maybe two gauges up on critical circuits. Use the same wire color coding as the wiring diagram if possible, if not then use colored shrink wrap on the ends (matching the wiring diagram) so you can easily identify circuits.
1978 KZ650B2 modified project
Last edit: 25 Oct 2025 10:33 by Injected. Reason: info
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
25 Oct 2025 12:11
#918369
Please try and keep to "one thread per topic" there was already a lot of advice on your other post - I have now merged the two
  • newt14
  • newt14's Avatar Topic Author
25 Oct 2025 14:16
#918372
Thank you - very helpful information.  procure multi core wire sized relative to 'current draw'
  • newt14
25 Oct 2025 14:25
#918374
Oh yes, absolutely - I have decided to build from scratch.  Im interested in taking on the project and learning about the different circuits along the way
