building a new wiring harness
- newt14
23 Oct 2025 07:29
79' KZ650 B3
I am looking to build a new wiring harness. Any recommendations on the type of wire to use? The most reliable robust option available.
-Rusty
-Rusty
- newt14
Re: wiring-harness/loom
23 Oct 2025 14:00 - 23 Oct 2025 14:02
Hello everybody,
Owner of a 79' KZ650 B3 for around 10 years now (its been active maybe 3-4 seasons/years of that time) - it has never had a dependable electrical system. It has consumed at least 4 batteries, 3 regulator/rectifiers - it does not seem to consistently charged the battery. My goal is to make the electrical system as dependable as possible. I've read this bike does not have the most robust electrical system. Working with electronics for some time I am aiming to rebuild the system beginning with the wiring-harness/loom. I would like to remove the electric-starter system completely (kick only).
My first question is: What type of wire and connectors to build this harness with?
I recently held a position testing RF cables and learned about discontinuities and how they are related to signal-integrity / power transmission. I enjoy working/learning with electricity + magnetism and have a reliable multi-meter and bench power-supply.
Glad to be here and any advice or opinions are appreciated.
Attachment not found
Last edit: 23 Oct 2025 14:02 by newt14.
23 Oct 2025 15:08 - 23 Oct 2025 16:17
Looks like the ship has sailed...
Regarding the charging system, it's actually quite simple to make a reliable system on bikes using a three phase system.
First step, buy a Shindengen SH775. This is a series type R/R, which will protect your stator from frying.
Second step, buy a quality stator such as a Rick's.
Third, wire it like this. The diagram was originally created for GS Suzuki bikes, but it can be executed on KZ bikes easily enough also.
NOTE: The power connection, red wire, is the only place you need to tap into the original harness. All other wiring should be new.
One warning: there are tons of fake SH775's in the marketplace. Buy a used one off ebay, and make sure you can read "SH775" printed on the top fin. You can find these for about $50 shipped, and they are super robust and almost never fail.
SH775 Install
by
nessism
, on Flickr
Last edit: 23 Oct 2025 16:17 by Nessism.
The following user(s) said Thank You: newt14
- JR
23 Oct 2025 16:08 - 23 Oct 2025 16:20
For connectors terminals etc check out Vintage Connections. I found them very good. Spend the money and buy a good quality ratcheting crimper. You wont regret it. They also sell wire. A buddy had a wiring loom out of an old pickup from which I salvaged most of the wire I needed. As far as I can remember I think I used mostly 18 gage (18AWG).
Check the Filebase tab above for a colour wiring diagram. I had a quick look, didn't see one for the B3 but may have missed it.
www.vintageconnections.com/collections/all
Last edit: 23 Oct 2025 16:20 by JR. Reason: Added URL
- gd4now
- Denco where did you go?
23 Oct 2025 18:28
I did not see one in the filebase other than a West German one for the B# and C3. I have this one from a scan of a manual. Not sure that you need it but thought it might add to the topic.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- newt14
23 Oct 2025 19:09
thank you for the input Nessism -
what ship are you referring to?
Last time I tested them, the RR and stator are functional, although I can test them again. The harness is very deteriorated.
I was asking what type of wire is recommended to build the loom with. I was considering Raychem spec 55. 16 gauge seems the size. store.emhmotorsports.com/raychem-spec-55-wire-single-core/
The current loom uses multi core - is this single core acceptable for a motorcycle application? I understand you lose some flexibility.
- newt14
23 Oct 2025 19:25
thanks for the vendor recommendation JR - I'll take a look. I do have the wiring diagram
- newt14
23 Oct 2025 19:37
Thank you for the file gd4now - I have been using this diagram from the clymer manual. Yours is drawn differently and the colors are helpful. Thanks. The more information the better.
- JR
23 Oct 2025 20:40
Answer
Use the multi strand
Answer
The following user(s) said Thank You: slmjim+Z1BEBE, newt14
24 Oct 2025 03:17Single core cable is intended for buildings and "fixed structures" it is absolutely not suitable for automotive use. Aside from the lack of flexibility it is susceptible to fracturing due to "vibration fatigue". You should use "thin wall" multistrand cable. Thin wall refers to the insulation, automotive only uses 12v (generally) so thin wall is best for flexibility and also to prevent ending up with a loom the size of a "baby's arm". With regards gauge you need to look at the current flow in the circuit then use a calculator (there is a link to one in my elec fault finding guide) to establish wiring gauge which ensures a "volt drop" of less than 0.2v. Below is an example of a chart I put together for another member ref wire gauge for his projectthank you for the input Nessism -
- slmjim+Z1BEBE
24 Oct 2025 03:43
Dry vinyl tape for building & repairing wiring harnesses. It's what Mama Kaw used & likely still uses
Dry vinyl tape adheres firmly to itself when spirally wrapped. It doesn't leave adhesive residue behind when unwound as electrical tape does. Secure the loose ends with a couple of wraps of electrical tape.
Not necessarily recommending this vendor, posting only as example. We bought dry vinyl tape on amazon.
www.summitracing.com/parts/sum-165110
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
The following user(s) said Thank You: sf4t7, Wookie58, newt14
24 Oct 2025 05:59Do you want functional or most reliable? They are not the same thing.thank you for the input Nessism -
