First Post chain drive to shaft drive
- sKZballs
Re: First Post chain drive to shaft drive
13 Jul 2025 11:17
so valve lash is 004 to .008. Double checked and It's .004-.008. Not great but will that make the compression bad also?
13 Jul 2025 11:26It won't help but I doubt that alone is giving such low readings (you need around 100psi for combustion to occur cleanly) what shape is your battery in ? it needs to spin the motor effectively to build pressure - also where you holding the throttle wide open when testing ?so valve lash is 004 to .008. Double checked and It's .004-.008. Not great but will that make the compression bad also?
13 Jul 2025 12:35
Just in case you have not already done this, please read and memorize everything on Lou's website, then download it all, and maybe print it all just in case.
s3.amazonaws.com/gpzweb/CamsKZZXZR550500...KZZXZR550500400.html
- sKZballs
13 Jul 2025 13:30
It wa a new battery with throttle closed. I let it crank a long while to reach it's peak pressure.
- sKZballs
13 Jul 2025 14:24
Texas, I will recheck my lash using those procedures and see what I have. Thank you
13 Jul 2025 18:49
Compression should be checked with a hot engine and throttle wide open.
- asphalt900
14 Jul 2025 02:22
If everything looks intact, don't be overly concerned with those low compression numbers. Because they have been probably sitting for years a few things can happen in slumber mode. Rings could be stuck to piston. Put your favorite oil down each sparkplug hole and let it sit there for a while, maybe a week? Rotate engine every couple days. Know that half your valves were open during it's nap. Built-up old carbon can get gummy especially if oil seeped past seals/guides and soak into carbon or it was running rich when parked. Either way you'll have a paste/chunks that keeps the valve from seating. If too long in a wet storage environment, valve faces and seats can rust/pit. Also note a Leak-Down test would be far superior to a pedestrian compression test. Have Fun!
- asphalt900
14 Jul 2025 02:29
Also noteworthy. Don't be too concerned with those valve shims yet! At least you know now .004-008" they aren't too tight. I would be a bit concerned with those .008 numbers though. Means the valves are not fully seating. Want to start it and bed those valves in again first before shimming.
The following user(s) said Thank You: kimchella
14 Jul 2025 02:38Great advice as usual Clay, Can I just add that you should spin it over on the starter with the plugs removed to "blow out" any excess oil in the cylinder before attempting to start it. If you where "enthusiastic" applying the oil it could cause the cylinder to "hydraulic" and damage a con rod etc !!If everything looks intact, don't be overly concerned with those low compression numbers. Because they have been probably sitting for years a few things can happen in slumber mode. Rings could be stuck to piston. Put your favorite oil down each sparkplug hole and let it sit there for a while, maybe a week? Rotate engine every couple days. Know that half your valves were open during it's nap. Built-up old carbon can get gummy especially if oil seeped past seals/guides and soak into carbon or it was running rich when parked. Either way you'll have a paste/chunks that keeps the valve from seating. If too long in a wet storage environment, valve faces and seats can rust/pit. Also note a Leak-Down test would be far superior to a pedestrian compression test. Have Fun!
- asphalt900
14 Jul 2025 03:25
Gotta put a warning sticker on everything, ha. Thanks for picking up my slacker typing Wookie!!
- sKZballs
14 Jul 2025 05:55
It will not start so that's why I'm taking it apart. I will say that, having taken the cover off, the chain is very tight. Like a drum. I will look into the leak down test and check that out. Thanks for the advice!
14 Jul 2025 06:46It's still worth "soaking" the rings with penetrating oil as suggested, nothing to lose and potentially a lot to gain. Also once it's had some oil in it if the compression picks up that would indicate the loss as being the bores as opposed to valve relatedIt will not start so that's why I'm taking it apart. I will say that, having taken the cover off, the chain is very tight. Like a drum. I will look into the leak down test and check that out. Thanks for the advice!
