First Post chain drive to shaft drive
- sKZballs
09 Jul 2025 14:09 - 09 Jul 2025 16:11
Hello, I have a 1982 550 A2 that I've had for many years that is in bad shape. The engine has run recently but did have water in cylinder 4. I also recently bought a 550 c thinking I could use some of the parts for swap. The c is probably the best bet for rebuild honestly but the A2 was my first bike. I got it when I was in the Marine Corps in 1983 and it has been following me around ever since. Anyway, I got eh C thinking I could swap the engine out if I needed to. Well the C is a shaft drive and I'm wondering about swapping the engine and drive. Would that be possible without major mods or am I looking at cutting and welding to make it work? Alternatively, could I simply swap the engine out?
Last edit: 09 Jul 2025 16:11 by Street Fighter LTD.
Re: First Post chain drive to shaft drive
09 Jul 2025 23:46
Welcome from the UK
- H1Vindicator
10 Jul 2025 07:49 - 10 Jul 2025 07:49
550c = Ltd chain drive. 550f/m = shaft drive; spectre or Ltd-shaft.
Last edit: 10 Jul 2025 07:49 by H1Vindicator.
- sKZballs
10 Jul 2025 08:07
LTD Shaft drive I guess. As I said, I'm new. Thanks for the clarification.
- StreetfighterKz
10 Jul 2025 08:16
Welcome in!
The chain drive chassis is not designed for a shaft drive setup. The pivot is too narrow to accommodate the driveshaft and is set up for a through-bolt pivot that is not possible with a shaft drive swingarm.
You may be able to reuse the top-end from the shafty engine on your A2 though.
Either way, it won’t be simple.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- sKZballs
10 Jul 2025 08:32
Thanks Doug, I might have to get the LTD going then work on the a2. I did misspeak. The A2 is an 81 and the LTD is an 83. I'm sure this doesn't change things as far as the swap though. Looks like I have two projects rather than one. Thanks for the info! I'll be back asking more questions as this process proceeds.
10 Jul 2025 08:41I would suggest tackling them one at a time unless you have a significant budget and strong control of your metal wellbeingThanks Doug, I might have to get the LTD going then work on the a2. I did misspeak. The A2 is an 81 and the LTD is an 83. I'm sure this doesn't change things as far as the swap though. Looks like I have two projects rather than one. Thanks for the info! I'll be back asking more questions as this process proceeds.
- H1Vindicator
11 Jul 2025 07:49 - 11 Jul 2025 08:12LTD Shaft drive I guess. ... the LTD is an 83.
partzilla. 1983 KZ550-M1 Ltd Shaft. www.partzilla.com/catalog/kawasaki/motor...3/ltd-shaft-kz550-m1 . closest match is probably the 1984 kz550-F2. there's also an 83 spectre F1 shaft but it's gold and black. side note. kawasaki kind of messed up the model lettering. seems like the spectre should have been the M1 and the Ltds should have been the F1/F2. or vice versa w F1 spectre and M1/M2 Ltd. edit. but a lot of parts are probably interchangeable. the colors don't matter. haha .
Last edit: 11 Jul 2025 08:12 by H1Vindicator.
- sKZballs
11 Jul 2025 08:00
Thanks H1. I'm kinda glad it won't work. I'll have to start on the LTD to get my hands dirty and it seems like a much easier project. The A2 is kind of a basket case. Once I get the LTD running I can dive into it with more knowledge and experience.
The following user(s) said Thank You: H1Vindicator, Wookie58, kimchella
- sKZballs
12 Jul 2025 17:02
well i cleaned out the carbs a bit, they really aren't bad. I got a battery and a compression tester... compression number are 45, 70, 90 and 130 psi but they all seem to hold the pressure. Is this thing worth building at this point? How far into it should I go and what would be the next steps to figure that out?
13 Jul 2025 02:01
Have you checked valve clearances ? (Lash)
- sKZballs
13 Jul 2025 07:20
I have not. I took the valve cover off last night and that is what I will be doing today. Everything in there looks ok but that's not really any indication. At least it's not rusted so that's a positive sign. I'll check the lash then remove the head I guess. I hear it's imperative not to drop the chain into the block. Any other reason to keep tension on the chain during this process?
