First Post 1977 Kz 1000
- HamFam
18 Jun 2025 10:46 - 18 Jun 2025 15:45
I have a 1977 kz 1000 with 52,000 miles on it. I have no idea what needs to be replaced and what has had work done. The problem I’m running into right now is the bike won’t go over 6k rpms it hits a wall. I took the carbs off and cleaned them. It’s still doing it. I’ve looked for the adjustment screws but I only see one on each carb near the intake. Is there another one for fuel I don’t see or is it just one screw for both. Not sure never ever worked on carbs or have had anything with them. Thank you!
Last edit: 18 Jun 2025 15:45 by Street Fighter LTD.
- rstnick
Re: First Post 1977 Kz 1000
18 Jun 2025 18:40
Welcome.
I believe there's some carb info in the filebase area on the forum here.
Look for a service manual downloads as well if you don't already have a manual.
Do post up some pictures of your KZ.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
The following user(s) said Thank You: HamFam
- StreetfighterKz
18 Jun 2025 18:52
Hey HamFam,
The screws near the head intake boots are pilot screw fuels. They only control a little of the throttle position; basically idle to 1/8 throttle if that. You’ll need to see what jets sizes are in the carbs. That should help us determine what’s going on.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
18 Jun 2025 19:43 - 18 Jun 2025 19:55
Welcome aboard.
The problem could be a rusty ignition advancer. Might be a fuel delivery problem. Could be a rat's nest in the air filter box or exhaust system.
In addition to the pilot mixture screws, there are synchronizing screws that adjust the throttle valves to each other and an idle adjustment screw for setting the idle speed. It is highly unlikely that any of them are causing the problem.
I recommend doing all of the routine maintenance listed in the factory service manual and the owners manual.
Here is a copy of the factory service manual. www.kzrider.com/filebase-alias?task=down...id=1159&catid=20&m=0
Last edit: 18 Jun 2025 19:55 by TexasKZ.
- asphalt900
19 Jun 2025 01:16
Sounds like a new acquisition? Because you said you don't know what has been done/replaced. More info Please/pictures! Does it have original Exhaust and Airbox? Open baffle/alternate exhaust will cause that 6K RPM limit. Those brass screws, fuel or air won't have any effect on your symptoms if it's not revving past 6K. If all else is OK, need to jump to a bigger main jet.
- slmjim+Z1BEBE
19 Jun 2025 06:01
Synopsis of above:
Full evaluation of motor health. Valve lash, static and dynamic spark timing (ignition advancer), spark energy, float height, hot compression #'s, clean air filter(s).
Pods?
Any mods to intake or exhaust systems?
Does it not rev past 6K in 1st.? Or in 5th.? If the latter, final drive gearing?
Visible carb adjustment screws only affect idle up to ~1/4 throttle. Above that is needle jet & jet needle up to not quite WFO. Full throttle is dependent on main jet, float height and, to a lesser extent, fuel flow (petcock & fuel filter) capabilities from tank to carbs.
Recommend not going immediately to carbs until everything else is well-known and good.
Good Ridin'
slmjim & Z1BEBE
Pods?
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- HamFam
19 Jun 2025 19:19 - 20 Jun 2025 18:02
Yeah my distant father left it to me in his will and I really have zero idea what was done to it. I don’t actually have that many pictures of it put together haha
I have cleaned the carbs,
New battery,
new plugs and wires,
new cables,
cleaned brakes up,
cleaned gas tank,
New battery,
new cables,
cleaned brakes up,
cleaned gas tank,
Last edit: 20 Jun 2025 18:02 by Street Fighter LTD.
- asphalt900
20 Jun 2025 01:43
Yes...you have the worst case scenario for stock carbs. Pods AND open 4-1 header. As everyone has mentioned, pull those carbs again and record the #'s on the Main and Pilot jets and report back.
The following user(s) said Thank You: MFP-Joe, Gdizard, HamFam
- HamFam
20 Jun 2025 09:03 - 20 Jun 2025 18:03
Last edit: 20 Jun 2025 18:03 by Street Fighter LTD.
- asphalt900
21 Jun 2025 01:39
Those carbs are not stock, they are 29 Smoothbores. Note the little phillips screw on one side. The two sizes provided, 07.5 and 2.5. Probably look closer and there will be a one so 107.5 , need something like a 115-120 to begin with. The other 2.5 is the float seat, nothing needs to be altered on that. There's another jet in there too, the pilot jet. But if it starts/idles then you're ok. And don't remove that little phillips screw!! Sounds like you're not familiar with these and that little screw sets the slideblock.
The following user(s) said Thank You: Gdizard, HamFam
- asphalt900
21 Jun 2025 02:32
Noteworthy!! Don't over-tighten the Jet Holder or also called the emulsion tube. Its the 8mm socket brass that is holding the 107.5 main jet. Strip-out the slide/Jet block and you're screwed!! Looks like this, lower one in picture.
The following user(s) said Thank You: SWest, Gdizard, HamFam
- HamFam
21 Jun 2025 04:22
Yes not familiar at all haha, but I didn’t unscrew anything yet. The 6k rev limiter I feel I’m hitting happens in all the gears. Bike starts right up idles well, it’s just that 6k wall I hit.
