New! to me 1979 kz750 pictures for attention
- SeaCur
03 Oct 2019 07:06 - 03 Oct 2019 07:10
She's pretty, she just doesn't start I guess. I kicked her a couple times to turn the engine over, and that's fine. "Ran a few weeks ago" said the seller. I know the headlight doesn't turn on with the bike, and there's a strong smell of gasoline in my garage now, so it's leaking fuel somewhere.
I'm new to the old bike world, so I'm hoping there's at least a few of you here that are active and can point me to parts.
Any tips on where to start I'd love to hear, otherwise I've got the service manual and will start at the beginning.
Last edit: 03 Oct 2019 07:10 by SeaCur. Reason: pictures inline
- ThatGPzGuy
Re: New! to me 1979 kz750 pictures for attention
03 Oct 2019 07:12
Welcome to the Forum. Not a bad looking twin but I still say the side covers are the ugliest things in motorcycledom.
Check the basics. Is there spark? You smell gas so there is fuel somewhere but I suggest pulling the carbs and cleaning them thoroughly.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- SeaCur
03 Oct 2019 09:57ThatGPzGuy wrote: Welcome to the Forum. Not a bad looking twin but I still say the side covers are the ugliest things in motorcycledom.
Got rebuild kits and floats from ebay coming, I'll rebuild tuesday.
I figured with the gas leak step one was checking out the carb floats and rebuilding. That would cause both my leak and stop me from starting. It was a long day yesterday picking her up and dropping off the uhaul an hour each way, didn't have time to see if there's spark yet.
- kzsolo
03 Oct 2019 11:42 - 03 Oct 2019 11:43
Agree that the carbs will need a thorough cleaning. Check the petcock too. Mine would not shut off properly so I got a new one. I rounded the back corners of the side covers to make them look better. Also did a two-tone paint to make them visually smaller. See pics.
Last edit: 03 Oct 2019 11:43 by kzsolo.
The following user(s) said Thank You: SeaCur
- SeaCur
03 Oct 2019 11:47 - 03 Oct 2019 12:03kzsolo wrote: Agree that the carbs will need a thorough cleaning. Check the petcock too. Mine would not shut off properly so I got a new one. I rounded the back corners of the side covers to make them look better. Also did a two-tone paint to make them visually smaller. See pics.
What size is the petcock? I'll just order one now for good measure.
Are they vacuum operated too? (Manual makes me think it is not)
Last edit: 03 Oct 2019 12:03 by SeaCur.
- AtLarge
05 Oct 2019 05:58
Not bad. Seen much worse. Good luck!
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
1994 BMW K1100RS
- DoctoRot
05 Oct 2019 14:14 - 05 Oct 2019 14:18SeaCur wrote: Got rebuild kits and floats from ebay coming, I'll rebuild Tuesday.
Use as much of the original jets, needles, etc... as possible. The KZ750 rebuild kits use a lot of generic parts that are not exactly the same as OEM. Take particular note of the float needle valve size.
I would suggest getting a steel fender or a fork brace or both, they do a lot to stabilize the front end.
also check the points and see that they are clean and gapped properly.
Last edit: 05 Oct 2019 14:18 by DoctoRot.
