new member '80 kz1000st
- irvin
28 Mar 2017 13:13 - 28 Mar 2017 13:35
Hi
I'm from France and a proud owner of a '80 kz1000st. It had been waiting for years in the middle of nowhere in the south of France until I got it from my father in law.
After many months working on it it is now almost running as good as new.
I've been lurking there for weeks gathering informations on how to fix it and thought it would be nice to say hello and thanks !
I also own a '73 super beetle, a '72 vw bus and my "modern car" is a '92 Peugeot 205.
You can find pictures of the bike here:
z750.bbconcept.net/t5395-nouveau-du-finistere
And the beetle there:
www.1302-03only.com/t4632-ma-1303-casimir
That's links to French forums but the pictures speak for themselves, you don't have to read the comments
Edit: I almost forgot I have a video of the bike running at low rpms after I sorted out its ignition and carburetion issues:
Last edit: 28 Mar 2017 13:35 by irvin.
- aquaholic
- 1981 KZ1000 J1
Re: new member '80 kz1000st
28 Mar 2017 17:12
Welcome. There is a ton of people here on this site that love to help and share parts and information. Nice looking ride. Enjoy it and once again, Welcome.
The following user(s) said Thank You: GPz550D1, irvin
28 Mar 2017 20:01
Welcome, good job.
The following user(s) said Thank You: aquaholic, irvin
- irvin
16 Jun 2017 02:20
Hi all,
I finally managed to get the motor, coils and carbs working reliably but I still had some electrical issues with the fuse box, the main fuse kept blowing and the fuse box was hot as soon as I started the bike. So I decided to have a deeper look and I immediately found what was wrong, I think the picture speaks for itself:
You can't see it on the picture but the plastic was melted around the fuse holding pins and the cables had a ton of verdigris several centimeters into the sheath. Given the very bad shape of the fuse box I thought it would be safer to bypass it so I bought some nice waterproof ATC blade fuse holders and soldered them in place of the original box:
I put some heatshrink tubes with the same color as the original cables close to the fuse holders in order to be able to tell them apart easily and keep something coherent with the original wiring diagram. As I hate to make irreversible modifications I kept the original fuse box and I use it to store spare blade fuses. I have yet to find a way to hold the cables safely but nonetheless it's working way better than before, I have 7 amps going through the main fuse motor running and headlight on, it's not hot at all anymore and that's quite far from the 20 amps max the fuse can withstand.
16 Jun 2017 08:00
I had the same problem. After cleaning it over and over I finally got a 30 amp fuse block to use as the main. That left a slot for my cigarette lighter that doubles as a accessory port for my air pump and USB adapters.
- irvin
16 Jun 2017 08:10
Actually I saw your post about your 30 amp fuse while searching through the forum for possible explanations about my fuse box getting so hot. At first I was going to bypass only the main fuse but when I saw how bad the wiring was I had no choice but to rewire anything. Furthermore these blade fuses are much easier to find if you break down in the middle of nowhere.
16 Jun 2017 08:32
Good move.
- irvin
17 Jun 2017 10:41
Damn I spoke too fast, I have a shortcut somewhere on the brake lights cable... I'll try to find it next week.
- irvin
18 Jun 2017 06:39Please Log in or Create an account to join the conversation.
- rstnick
18 Jun 2017 08:06 - 18 Jun 2017 08:53
Welcome Irvin.
Nice Z1000 ST you've found.
What fairing/wind screen is on there?
I have not seen one like that before.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 18 Jun 2017 08:53 by rstnick.
- irvin
18 Jun 2017 08:17
Hi
I don't know much about this fairing, a guy here who also owns a ST told me it was called "stratale" but I don't know if it's the manufacturer name or the model name.
- irvin
01 Dec 2017 13:07 - 01 Dec 2017 13:09
Hi,
I couldn't ride for the last two months but that was for a good reason, my seat was in a bad shape since I got the bike, hopefully a friend of mine is a very talented saddler* and he performed his magic tricks on my seat, here is the result:
There are more pics there, on my friend's facebook wall: fr-fr.facebook.com/Authentic-Sellerie-Li...val-497597687242429/
* I don't know if this is the right word in English, his job is to restore old cars' seats and make them better than new. I'd like to know what's this job's name in English if it's not "saddler".
Last edit: 01 Dec 2017 13:09 by irvin.
