Hello from Northern Arizona
- Jasonray
22 Oct 2016 09:06
Hello All,
My name is Jason and I picked up a '78 KZ650 basket case/roller about 3 years ago and just stared working on it this spring. It is titled a '78, but the VIN aligns with a '79 D2. Couldn't really tell because it had no tank, no wiring, no bars, no seat, etc.
After months of work, I have it running and ride it daily. This forum has helped a lot, so I thought I should "do the right thing" and say, "Thank you."
I have started to realize this beast will be an ongoing maintenance project, so I expect I'll be getting much more involved...if I don't pull my hair out trying to find parts up here in a small town.
Cheers,
Jason
Cheers,
Jason
1979 KZ650 Basket Case
- slmjim+Z1BEBE
Re: Hello from Northern Arizona
22 Oct 2016 10:28
Hell Jasonray,
We pretty much have tunnel vision for Z-1's, so we won't be much help on later or smaller Z-bikes, but it's nice to see the old Kaws being kept alive.
Welcome.
Good Ridin'
slmjim & Z1BEBE
Welcome.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
The following user(s) said Thank You: Jasonray
22 Oct 2016 14:00
There's lots of smaller four owners here obviously. Any bike takes work, that's half the fun.
22 Oct 2016 18:22
Welcome aboard!
Amazon, fleebay, FedEx, Z1E and forum members make small towns less of a disadvantage than they used to be when it comes to finding parts.
Some pics would be nice.
- rstnick
24 Oct 2016 16:51
Welcome Jason.
I second the request for pictures.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Jasonray
24 Oct 2016 17:15
I need to dig up some true before photos. In the meantime, here are two pics.
I had no idea what I was doing when I started this project, so I went on ebay and started buying the least expensive stock parts I could find to try and set a solid base. Bought stock handlebar with controls, headlight bucket with mount, dual front brake lines and splitter, and a seat cover. That is the first pic with the black tank. Got the bike running after rebuilding the carbs, and replacing the points and condenser. Had to then buy the gauges so I had somewhere to put the ignition. Then bought a tank with far fewer dents than the black one, replaced the reg/rec, stator and rotor and NOW I feel I have a good base.
Oh yeah, also replaced the fork springs and seals, plus the original front mag was outta spec causing a severe wobble at 60+ mph, so that was swapped with an eBay purchase and lastly, changed to needle bearings in the steering stem.
Again, I feel I'm at a good base, with A LOT of new motorcycle knowledge. And all for $900 (including the new tires which I learned to mount and balance myself). I've been riding a '93 Harley 883 for years, but I have learned more from this Kawasaki in the past 7 months than I ever dreamed.
24 Oct 2016 17:38
Good job.
