Hi all. kwak750ltd here
- kwak750ltd
27 Aug 2016 04:51 - 27 Aug 2016 05:22
I live in England and have had in the past a 440 ltd which I loved. My 50th Birthday came around in August so I got myself a nice little 750 ltd from e.bay. I think it was sprayed up by Stevie Wonder and had a lot of problems . I was blessed with having 2 weeks off work soon after so in the shed I went. First job was to strip the back frame down leaving the wheel in place and sand down the frame for a spray up. 33 years had not been kind to it, so I started a restore job. Finding things like the rear plastic mud guard broken by the bolts and rust coming through the rear fender. Moving forward to the battery box and the wiring. Still don't know where the ignition module is ment to be mounted ?. Spayed frame up as far as rear engine mounts and ordered some new parts for it. Still a a big to do list like cam chain rattle ( that is bad. ) Carb clean and balance, but first need to sort gearing out as engine is at 4200 rpm in top gear at 45- 50 mph. Loads to do. So little spare time to do it.
Attachment Bat8small.JPG not found
Attachment Bat13small.JPG not found
Attachment Tank2small.JPG not found
Attachment Tank5small.JPG not found
Attachment Tank6small.JPG not found
Attachment Outandaboutsmall.JPG not found
Last edit: 27 Aug 2016 05:22 by kwak750ltd.
- kwak750ltd
Re: Hi all. kwak750ltd here
27 Aug 2016 05:38
This is the edited pic of it on e.bay. A little different now.
Attachment 750ltdforsalesmall.JPG not found
27 Aug 2016 06:19 - 27 Aug 2016 06:23
Howdy. If by ignition module you mean the igniter, it's bolted to the left side electro bracket, directly behind the fuse box.
Left side -->> electro cover removed. Igniter hidden behind fuse box. the 650-CSR is very similar to your Ltd.
Last edit: 27 Aug 2016 06:23 by martin_csr.
- kwak750ltd
27 Aug 2016 06:44 - 27 Aug 2016 06:56
Thanks for the reply. Mine seems different to your's.
There is no space behind that or any mounting holes. See other pics here.
Attachment Bat11SMALL.JPG not found
Attachment Bat12small.JPG not found
Attachment Bat5small.JPG not found
Attachment Bat3SMALL.JPG not found
Last edit: 27 Aug 2016 06:56 by kwak750ltd.
- GPzMOD750
The following user(s) said Thank You: kwak750ltd
27 Aug 2016 07:40 - 28 Aug 2016 06:35
My mistake, then. my csr should have the same battery box & electro bracket, but yours look different. doh.
What year is your Ltd?
Last edit: 28 Aug 2016 06:35 by martin_csr.
- kwak750ltd
27 Aug 2016 08:20 - 27 Aug 2016 08:28
I suppose I should start from the time i got it. The 1983 750 ltd H3 came to me about 3-4 weeks ago . The first 2 weeks were spent living in my shed ( that's me , not just the bike. ) It's an American import with 49,000 on the clock. It was all black and sold with 11 months m.o.t. I'm not going to tell you the price. As it's 33 years young it needed a little tlc and to have it the way I would like ment a part strip down. I am no way a mechanic or a paint sprayer. But do like tinkering. First job was the back end. Looking close, you could see rust on all part's and under the seat was not much better.
So here are some of the other pic's I took during that time
Will show more pic's in a while when I convert them to a good size.
Attachment Backend1small.JPG not found
Attachment Backend4small.JPG not found
Attachment Backend8small.JPG not found
Attachment Bat1samll.JPG not found
Attachment Burntwiresundertanksmall.JPG not found
Attachment Burntwiresrepairedandframesprayedsmall.JPG not found
Last edit: 27 Aug 2016 08:28 by kwak750ltd.
- rstnick
29 Aug 2016 17:46
Welcome, and Happy Birthday!
Nice work on the 750 so far.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
