80 kz 1000 difference 80 kz 1000 ltd
  • PLUMMEN
  • PLUMMEN's Avatar
Re: 80 kz 1000 difference 80 kz 1000 ltd
10 Apr 2016 21:17
#720258
Rockranch wrote: The MkII and ST engines appear the same externally, yet were much different internally in many ways also including their crankshafts, stators, cases etc etc etc...though they will mount right into most any other KZ1000 and even the earlier 900 frames all the way back to the '73's without any mounting mods. That's why the MKII motors are popularly sought after for big bore and drag racing engine builds for their beefier cranks and cases. The ST (shaft) engines are the same motor internally as the MKII's and can be converted to sprocket drive, as I found out with the one I recently bought...
Attachment 2015-11-22001002.JPG not found
Attachment 2015-11-22001001.JPG not found
.............................Mike
Vroom-vroom!!!
Theres a whole hell of a lot more big inch turbo dragbikes out there running small pin cranks and old style cases than they ever made of the mkII versions. ;)
  • Rockranch
  • Rockranch's Avatar
11 Apr 2016 04:34 - 11 Apr 2016 06:27
#720271
Then there's a hell of a lot of people out there that I've encountered either in person or via various online sites that have no idea what the hell they're talking about!. Go figure.
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!) :)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
Last edit: 11 Apr 2016 06:27 by Rockranch. Reason: inc
  • PLUMMEN
  • PLUMMEN's Avatar
11 Apr 2016 08:00
#720316
Count the number of big motored drag bikes and street bikes out there that have been built raced since before the mkII bikes came out.
Then look at how many mkII motors that were built,Theyre a small percentage of the bikes that have been built/still raced .
Theres nothing wrong with the mkII parts theyre tough as hell,But if things arent put together right theyll blow apart just like any other motor.
And yes Ive had 5-6 of the 1980 1000 ltds over the years.
  • Rockranch
11 Apr 2016 10:29
#720369
I didn't say the MOST...obviously there would not be enough to go around lmao. NO engines are bulletproof when in the hands of speed-clock racing fanatics!
1 modified
  • PLUMMEN
  • PLUMMEN's Avatar
11 Apr 2016 11:00
#720372
I'm just saying that the mkIi is not as all mighty as some people want to make it out to be is all.
Take it for what ever it's worth,but if I was building a non turbo street track bike I'd use a 900 crank myself.
If I was building anot her turbo street bike I wouldn't have a problem using a small pin kz1000 crank that had been checked out and welded.
I know of a local 79 Ltd with the old style small crank that's been built into a high boost 1197 turbo that has never had any bottom end issues,Joe's motor puts well over 200 plus hp at the back wheel.
The following user(s) said Thank You: Rockranch
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
11 Apr 2016 12:58
#720388
ltd's didn't get leading axle forks until 81.
there are also external differences in the mk11 blocks and the small pin kz blocks.
  • PLUMMEN
  • PLUMMEN's Avatar
11 Apr 2016 20:21
#720458
531blackbanshee wrote: ltd's didn't get leading axle forks until 81.
Extra ribs on the cases by oil fill hole area is the most obvious differance to look for.
  • missionkz
  • missionkz's Avatar
11 Apr 2016 20:27
#720461
I thought he just wanted to know if there was an engine difference between the 1980 KZ1000 and 1980 KZ1000 LTD?
Seems like everyone has gone all over the place!! LOL
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
The following user(s) said Thank You: PLUMMEN
  • TexasKZ
  • TexasKZ's Avatar
12 Apr 2016 16:27
#720590
The OP says nothing about engine.
  • missionkz
12 Apr 2016 16:32
#720591
Right. I said I thought he was asking about the engine difference from Std to LTD.
Bruce
1977 KZ1000A1
  • TexasKZ
  • TexasKZ's Avatar
12 Apr 2016 16:49
#720595
Ah, gotcha. I wonder if we answered his question sufficiently ?
