80 kz 1000 difference 80 kz 1000 ltd
  • Reggie72
  • Reggie72's Avatar Topic Author
04 Apr 2016 12:32
#719244
Ok so I'm new here so what's the difference between the it kz 1000 and the kz 1000 ltd? I just got the kz 1000 Ltd and just worndering
  • TexasKZ
  • TexasKZ's Avatar
Re: 80 kz 1000 difference 80 kz 1000 ltd
08 Apr 2016 06:49
#719845
Most of the differences are cosmetic. The LTD was the more cruiserish version. Two level seat, buckhorn bars, leading axle forks, 19 inch front and 16 inch rear wheels, different mufflers, et cetera.
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Apr 2016 06:59
#719847
Longer wheel base too?
  • davido
  • davido's Avatar
08 Apr 2016 09:43
#719867
I read somewhere that,though they have the same engine,there are internal differences. Maybe the cams or the gearing. The LTD having more lower down torque and the KZ leaning more towards top speed.
Could be wrong.and it wouldnt be the first time!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • PLUMMEN
  • PLUMMEN's Avatar
08 Apr 2016 17:00
#719944
The LTD looks better imo. :laugh:
  • missionkz
  • missionkz's Avatar
08 Apr 2016 17:50
#719953
PLUMMEN wrote: The LTD looks better imo. :laugh:
The standard model with spoke wheels is the shizzle. I've always been under the impression the engines were identical but the gearing (if chain drive) was slightly lower in the LTD model.
Regardless, I like my LTD seat better on my bike but the bench seat still looks good.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
The following user(s) said Thank You: PLUMMEN
  • PLUMMEN
  • PLUMMEN's Avatar
10 Apr 2016 01:59
#720148
Im a sucker for wire wheels also,the last year for factory wire wheels was 78 though.
The 79-80 kz is a completely differant bike than the 73-78 kz,If you put wire wheels on a 79-80 1000ltd most people would think it was a 77-78 if they didnt know what they were looking at. ;)
  • Rockranch
  • Rockranch's Avatar
10 Apr 2016 03:35
#720150
Wheel size (total height of mounted inflated tires) can alter gearing slightly, same as different size rear sprockets. Clearly noticeable when standing them (16" vs 18" wheels) side by side.
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!) :)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
  • Rockranch
10 Apr 2016 03:47
#720151
Reggie72 wrote: Ok so I'm new here so what's the difference between the it kz 1000 and the kz 1000 ltd? I just got the kz 1000 Ltd and just worndering
Other than the styling, the engines were different . The engines of the KZ1000 'MKII's' and 'ST's' of '79 and '80 were different than the LTD models of the same year. ((Was there a standard model KZ1000 produced in '79 and '80 other than the MKII's and ST's?))...if so my year/model ID guide does not show one. .............................................Mike
Vroom-vroom!!!
1 modified
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
10 Apr 2016 06:04
#720156
For 1980, Kawasaki marketed the following big-bore four cylinder models:
KZ1000A4 aka standard 1000, MkII
KZ1000B4 aka LTD1000
KZ1000C3 aka Police
KZ1000D3 aka Z1R
KZ1000E2 aka Shaft
KZ1000G1 aka Z1 Special
Z1000H1 aka Z1000FI
ALL of which were equipped with the so-called MKII-style motors. As was mentioned , there were differences between models in carburation, camshafts, and many other areas, etc.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
The following user(s) said Thank You: 531blackbanshee, Rockranch
  • Rockranch
10 Apr 2016 07:04 - 10 Apr 2016 07:05
#720162
The MkII and ST engines appear the same externally, yet were much different internally in many ways also including their crankshafts, stators, cases etc etc etc...though they will mount right into most any other KZ1000 and even the earlier 900 frames all the way back to the '73's without any mounting mods. That's why the MKII motors are popularly sought after for big bore and drag racing engine builds for their beefier cranks and cases. The ST (shaft) engines are the same motor internally as the MKII's and can be converted to sprocket drive, as I found out with the one I recently bought...
Attachment 2015-11-22001002.JPG not found
Attachment 2015-11-22001001.JPG not found
Vroom-vroom!!!
1 modified
Last edit: 10 Apr 2016 07:05 by Rockranch. Reason: inc
  • PLUMMEN
  • PLUMMEN's Avatar
10 Apr 2016 21:14
#720257
Vroom-vroom!!!
The only differance internally Im aware of between the 79 kz and the 79 ltd was that the ltd used a smaller center crank pin like the 77-78 kz.
In 1980 they used the same parts. ;)
