1980 kz650f
- wader324
1980 kz650f
11 Jun 2015 10:13 - 11 Jun 2015 10:26
So, not only am I new to this forum, but I am also new to the motorcycle world.
I've been wanting to get into riding for a little while now, and this opportunity fell into my lap:
I just acquired a 1980 Kz650f. It belonged to my uncle's brother, who stopped riding about 15 years ago (parkinson's), and it has sat in their family's junk yard in Wisconsin ever since. So after 15 years of sitting untouched through wisconsin winters, it isn't running and is needing some rebuilding/updating and repairs.
I figured if I want to begin riding, what better way than rebuilding a bike and learning everything about it mechanically beforehand. (I will be taking motorcycle riders course and getting my license in the meantime).
I do have my buddy who is a big motorhead assisting me on this project, but was hoping you guys would also be willing to provide some insight, advise, and what have you as well.
I'm getting a server error when I try to add photos, so you don't get to see the bike yet.
But I have already pulled and cleaned the carbs.
Thanks ya'll
Thanks ya'll
Last edit: 11 Jun 2015 10:26 by wader324.
Re: 1980 kz650f
11 Jun 2015 10:47
The pics might be too large. If you can post them, it will help. Is it a rust bucket?
- wader324
- fixitmann
Re: 1980 kz650f
16 Jun 2015 06:53
Welcome, looks like you got some good complete bones to start from. You are in the right place. Good luck!
So the old Rocker gets out his bike to make a ton before he takes his leave. Up on the A1 by Scotch Corner
just like it used to be. And as he flies --- tears in his eyes ---
his wind-whipped words echo the final take and he hits the trunk road doing around 120 with no room left to brake.
Re: 1980 kz650f
16 Jun 2015 07:04
Pump nozzles. You may already know this, but test the accelerator pump by supplying fuel to the carbs then actuate the throttle pulley vigorously: fuel should squirt straight out the nozzles without hitting the carb bore walls.
Rear brake. I would replace the rear brake shoes. The adhesive that binds the linings to the shoes can fail over time, so a lining can separate from a shoe then get jammed between the shoe & drum, locking the rear wheel. It happened to me when rolling the bike off the center stand, so it does happen. I would get oem shoes or Vesrah (made in Japan). It has been reported that some aftermarket shoes don't fit right.
- missionkz
Re: 1980 kz650f
16 Jun 2015 11:16 - 16 Jun 2015 11:17
I'm just jealous... so many of you folks all seem to find these easy rebuilds and have two car garage shops with all that room to work on them in !!!
I'm standing on my head in the drive way or along side the garbage cans most of the time.... LOL
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 16 Jun 2015 11:17 by missionkz.
- rstnick
Re: 1980 kz650f
16 Jun 2015 15:48
Welcome.
Nice looking F model you've got there.
I think the engine might be from an earlier model, a '77.
You can check the engine #, stamped next to the oil fill hole, here: www.jarlef.no/Kawasaki/Series/Z/650/z650.htm
Accelerator pump carbs came out in '79,.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Re: 1980 kz650f
16 Jun 2015 16:20
There's those shark teeth again. Cool. :evil:
- RickKZ
Re: 1980 kz650f
19 Jun 2015 01:05
This is awesome! I'll be joining this project soon. Got an old beater for $200. It's a KZ 650 C1 I think. Cleaned the carbs and got it started. Motor seems ok so now it is all the time to make it look good
KZ 650 mono shock rebuild project.
KZ 440 Ltd bobber build for my wife
Re: 1980 kz650f
19 Jun 2015 06:37 - 19 Jun 2015 06:47
That's half the battle. I started polishing and painting parts that have not been touched in 30 years. No money, just time. Glad I did. When I finally got the money for the engine, I was half way there. PLS excuse the yard. I had a almost terminal case of the F it's. The bike brought me out of my FUNK. :woohoo:
Last edit: 19 Jun 2015 06:47 by SWest.
