f.n.g.
Re: f.n.g.
10 Apr 2013 15:02
no sweat man happy to be of assistance.there is a yamaha that has a direct acting shock.i thought it was the yzf600 (the slower version of the r6)that used one but i haven't been able to figure out which one it is.
keep us posted,
keep us posted,
- wireman
Re: f.n.g.
10 Apr 2013 15:41
Didn't the old ex250 and ex500s have a mono shock?
I would think they would be a reasonably close fit dimensionally wise ,and the bikes probably weighed close to same.
- wireman
Re: f.n.g.
10 Apr 2013 15:43Oh God,you had to bring stewie back up! :laugh: I offered to give him another frame to fix that mess if he promised not to try mono shocking it again,that was before he went off deep end for 9-10th time! :sick: :woohoo:650ed wrote: It's just that I have seen the precision engineering of some of the "custom bike builders" who are under the delusion that that can create a better bike as long as they have some welding equipment. I'm not saying this is your approach, as that remains to be seen, but here is just one example of someone who cut a perfectly good frame and then fixed it with their welder. I would not want to ride on that puppy. :laugh:
kzrider.com/forum/11-projects/426281-stu...20&start=1080#443535
- wireman
Re: f.n.g.
10 Apr 2013 16:06
Heres what I found on the ex250 suspension
Attachment ex250suspension.gif not found
Attachment ex250swingarm.gif not found
Re: f.n.g.
10 Apr 2013 16:17 - 10 Apr 2013 16:22
fwiw,
the 08 kawasaki versys uses a direct acting shock.
www.ronayers.com/Fiche/TypeID/26/Type/Sw...82076/Group/Swingarm
Last edit: 10 Apr 2013 16:22 by 531blackbanshee.
Re: f.n.g.
10 Apr 2013 16:27 - 10 Apr 2013 16:32
Wireman wrote "Oh God,you had to bring stewie back up! " :laugh:
There have been so many like Stewie's. Two of my favorites (shudder!) are below because they started with bikes like mine. Guys who knew for sure they could out-engineer the dummies at Kawasaki (who have tons of engineering education and experience) as long as they played it by ear and didn't put together a plan before firing up the good ole sawzall. :laugh: I don't wish bad luck on anyone, but the bikes I've seen that have been successfully modified and actually ridden are normally the result of a lot of hard work and careful planning. There are some very nice examples on this site, but not as many as those that end up being parts bikes. Ed
Here's one that started with a really cherry KZ650-C1 - except for 4 into 1 exhaust it was all original (including paint). Here's the last we saw of his Suzukimobile before he faded away. Why destroy every piece of the bike he bought if he wasn't going to use any of it? Did he toss it or finish it; I guess we'll never know for sure:
kzrider.com/forum/11-projects/451145-str...=20&start=200#539129
And then of course there's the water-cooled Sukuzisaki KZ650-C1. Gosh, it's really hard to believe this one failed:
kzrider.com/forum/2-engine/405631-4-valv...t=20&start=60#411244
Last edit: 10 Apr 2013 16:32 by 650ed.
- wireman
Re: f.n.g.
10 Apr 2013 16:28
What worries me about the direct acting shock idea is that the 400 probably weighs in the neighborhood of 350-400lbs,fitting the direct acting shock from a shock that weighs closer to 500 plus might make it tough to get a decent ride without spending money on an expensive shock with more adjustment to it.
Its all just speculation on m
y part of course until you take a tape measure and do a little research
Re: f.n.g.
10 Apr 2013 16:49 - 10 Apr 2013 17:03
a spring change can make the shock handle the weight.
08 ninja 650 also use a direct acting shock.
www.ronayers.com/Fiche/TypeID/26/Type/Sw...sion_Shock_Absorber_
there are a bunch of them on ebay for cheap to.
use search term,
kawsaki ninja 650r rear shock.
use search term,
Last edit: 10 Apr 2013 17:03 by 531blackbanshee.
- Plug.ugly
Re: f.n.g.
10 Apr 2013 20:55
Again thanks for the help, definitely intend to research the hell out of the direct action shock. Like I said, I'm in no way looking to reinvent the wheel here. I'm just updating the suspension. This technology has been around since at least the eighties. That ex250 set up uses a linkage and I'm hoping to avoid that if I can.
- jeffasaki
Re: f.n.g.
10 Apr 2013 21:28
wow at least they only butchered 650s id be pissed if those where 903s or 1015s
650ed wrote: Wireman wrote "Oh God,you had to bring stewie back up! " :laugh:
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Re: f.n.g.
10 Apr 2013 22:12 - 10 Apr 2013 22:13I hate to say it, but that first one (below) was a KZ1000.jeffasaki wrote: wow at least they only butchered 650s id be pissed if those where 903s or 1015s
Last edit: 10 Apr 2013 22:13 by 650ed.
- jeffasaki
Re: f.n.g.
10 Apr 2013 22:19
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
