new member and 1st time bike owner, 74 kz400
04 Feb 2013 16:32 #570738 by Lakeoffire
Hi my names Jeff and I'm from NJ and just bought my 1st bike a 74 kz400 for $400...I wanna make a bobber and have a good idea how i want it...my question is I want to extend my swingarm about 4" and don't know how to go about doing it...I read that a LTD swingarm is longer but Idk how much or if it would bolt up to a 74...if anyone knows where I could get an extended swingarm, or if there's another one thats longer that would bolt up to my bike I would appreciate the incite...and if neither of those are possibilities how do I extend it myself or if anyone knows someone that would do it for me...thanks again - Jeff
  • wireman
04 Feb 2013 16:49 #570740 by wireman
Replied by wireman on topic new member and 1st time bike owner, 74 kz400
From what I remember of the last 76 kz400 I had the swingarm was pretty flimsy looking at best in stock form to say the least,lengthening it would probably make the situation worse without a serious bracing job.
What are you planning to do with the bike?
Whats the width of swimgarm pivot tube? B)
04 Feb 2013 17:04 #570744 by 650ed
Have you considered the possibility of actually learning how to ride and getting some saddle time before venturing into motorcycle design, engineering, and fabrication? :whistle:
The following user(s) said Thank You: KZQ, Nebr_Rex, KZ250LTD, trianglelaguna
04 Feb 2013 17:22 #570749 by Lakeoffire
Replied by Lakeoffire on topic new member and 1st time bike owner, 74 kz400
I'm not sure what the width is, I haven't measured it yet....just to give ya and idea of what I'm tryin to do here's pictures...the blue one is my bike and the black one is what I want it to look like...
Attachment IMAG0019.jpg not found
Attachment img-1120282407.jpg not found
I'm going to ride the bike as is until I get all the stuff I need to make it a bobber, I just wanna know how to do it so when i do work on it I know how.
  • wireman
04 Feb 2013 17:31 #570750 by wireman
Well I can pretty much guarantee the shocks on the black version may as well be struts as theyre laid out they wont do much for ride quality! :sick: :woohoo:
And that swingarm is going to flex severely if those shocks do actually move any B)
04 Feb 2013 17:57 #570755 by Lakeoffire
So if I do figure out how to extend the swingarm I should just go with struts?
  • wireman
04 Feb 2013 18:03 #570756 by wireman
Id find a swingarm with bigger tubing if you do it,and move the shocks forward about 4" on the swingarm you they can actually operate.
Picture the swingarm as a big arc with pivot bolt as center and the axle as the outside of circle,it wants to operate in that area.
Then you have to figure an angle that the shocks will allow that to happen while they expand and compress as needed at same time.
Make sense? B)
04 Feb 2013 19:01 #570765 by Lakeoffire
Yeah, thank for the help B) when I start building it ill post pictures of how it's all going.
  • wireman
04 Feb 2013 19:42 #570768 by wireman
Measure the width between the frame tubes and the length from center of pivot bolt to end of axle and post it up here so we can get some ideas of what you need in the future B)
05 Feb 2013 10:42 - 02 Dec 2013 15:39 #570875 by martin_csr
Replied by martin_csr on topic new member and 1st time bike owner, 74 kz400
Howdy. The KZ400 is a neat motorcycle. You should go thru the bike & do all of the maintenance stuff, getting it in perfect riding condition. Be sure to refurbish the Fr brake & replace the Rr brake shoes if they are old - even if the linings are plenty thick - replace them. And ride it. Then sell it late for something bigger. A refurbished stock vintage bike might be easier to sell than one that has been modified. If the frame is cut, the value is probably decreased by $500. Once cut, it is ruined.
Last edit: 02 Dec 2013 15:39 by martin_csr.
The following user(s) said Thank You: Lakeoffire
05 Feb 2013 14:04 - 05 Feb 2013 14:08 #570888 by loudhvx
Replied by loudhvx on topic new member and 1st time bike owner, 74 kz400
That black bike is absolutely NOT how you want to lay out the rear shock. That rear geometry leads to a regressive suspension. You want a progressive suspension... where the shocks put more force on the swingarm as it moves upward. In extreme cases, a geometry, like on the black bike, can just collapse when a large enough bump is hit.
As the swingarm moves upward, the swingarm and shock should get closer to a right angle... not farther, as in the case of the black bike.
A strut in place of the shock will work, but will also be work to ride.
Last edit: 05 Feb 2013 14:08 by loudhvx.
05 Feb 2013 14:53 - 05 Feb 2013 14:53 #570892 by Kidkawie
Replied by Kidkawie on topic new member and 1st time bike owner, 74 kz400
I better find a 4-hundie before they're all gone! :(
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 05 Feb 2013 14:53 by Kidkawie.
The following user(s) said Thank You: trianglelaguna
