Hi I'm Ryan, I just got a 1980 KZ750
  • readmckay
  • readmckay's Avatar Topic Author
25 Jun 2011 04:19 - 25 Jun 2011 04:20
#459255
I haven't named her yet. But I'm excited to have her. My brother-in-law had her given to him a while back. He apparently has no interest in riding. I called him up to see if I could buy it off of him and he gave me the incredible deal of free :)
She needs a lot of work though. She's been sitting outside for a while. I'm a computer tech not a mechanic, and I just know how to change my oil and the like. I'm looking forward to learning though.
Anyway, everyone loves a good picture.
[IMG
You should be able to click on the picture to go to the entire gallery.
1980 Kawasaki KZ750 LTD (project)
2007 Honda Rebel
Last edit: 25 Jun 2011 04:20 by readmckay. Reason: Fixed link
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Hi I'm Ryan, I just got a 1980 KZ750
25 Jun 2011 06:47
#459259
Welcome...and you have the absolutely best kind of motorcycle...free :woohoo:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • trianglelaguna
  • trianglelaguna's Avatar
25 Jun 2011 08:02
#459264
welcome...all the info to keep that on the road another thirty years is here and some
keep safe and ask questions
Craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • Chaotic Reason
  • Chaotic Reason's Avatar
25 Jun 2011 12:53
#459293
Congratulations, nice brother-in-law, and nice bike. You'll meet a lot of people who love their kaws on here, and they love to help us new guys out. Enjoy the project.
Michael
1980 KZ1000 shaft drive
  • readmckay
25 Jun 2011 14:31
#459302
Thanks guys! I'm looking forward to getting to know you all better :)
2007 Honda Rebel
  • MFolks
  • MFolks's Avatar
25 Jun 2011 14:39
#459303
Every owner of an older bike, needs to do this once a while for maximum reliabilty of the electrical system:
Cleaning Motorcycle Electrics
Get some of the De-Oxit electrical contact cleaner and figure on spending a good day going from the front of the bike to the back. It’s a plastic safe cleaner/preservative. www.deoxit.com is their website.
On the older Kawasaki's, a majority of electrical connectors are inside the headlight housing requiring removal of the headlight, then the fun begins.
Do one set of electrical connectors at a time to avoid mixing up what connects to where. Usually disconnecting, spraying with De-Oxit and reconnecting is about all you'll need.
However, when encountering the green crud of corrosion, a brass wire brush may be needed on the pins you can reach. Some 400-600 grit wet and dry sandpaper strips rolled into a tube should reach the male and female pins in the more difficult to clean connectors.
Smoker’s pipe cleaners, cotton swabs and wooden toothpicks work as cleaning aids.
Really small electrical connectors may require the use of a welders tip cleaning tool assortment.
Most pins in the connectors are coated with a thin plating of tin, and others may be nothing more than copper or brass.
If moisture is added, the resulting corrosion lowers the voltage/current being carried causing dim lights, slow engine cranking, slow turn signal responce and lower input voltage to the ignition coils resulting in weak spark.
The left and right handlebar switch pods will need attention too as they have circuit functions like turn, horn, run/stop, and start.
Usually a spritz or two with actuation of the switch is about all needed for these switches unless corrosion is detected and then careful disassembly is required.
The ignition switch may or may be not sealed to allow spraying the internal contacts. I urge caution if attempting to open this up as springs, and ball bearings may fly out never to be seen again!
If your bike has the older style glass tubed fuses, I suggest replacing them as vibration can cause internal failure. AGX is the type used, and most auto parts stores can get them for you.
Clean the fuse holder clips, looking for signs of overheating(discolored insulation, signs of melting).
I use metal polish on a cotton swab, followed by spraying another clean swab with the De-Oxit and then rubbing the inside of the fuse clip.
All battery cables must be clean and tight for maximum current transfer. Check the cables going from the Negative(-) battery terminal/post to the engine mounting bolt
Also the one going from the Positive(+) terminal to the starter solenoid and from there to the starter motor.
If any battery cable feels ”Crunchy” when flexed, replace it as possible corrosion is inside the insulation.
Each "Bullet Connector" will have to be sprayed to ensure good connectivity, especially the ones going to the energizing coil of the starter solenoid.
The alternator output “Bullet Connectors” are usually behind the engine sprocket cover and will need inspecting and cleaning too.
The turn signal light sockets will benefit from a spritz from the contact cleaner along with the tail light/brake light socket.
Some brake light switches can be sprayed on the actuating rod, with the spray running down inside to the electrical contacts, others may be sealed requiring replacement if the switch is intermittent in operation.
Some people put the Di-Electric Grease on cleaned terminations/connectors, I don’t, as I’ve read/heard it can cause problems when it gets hot, actually insulating the connections, so the choice is yours to use or not.
And:
Why WD-40 Should Not Be Used On Motorcycle Electrical Items.
For many years, I was proponent of the use of WD-40 on fuse clips, fuses, switches and connectors. After hearing of other peoples experience with intermittent and sporadic activity, I shrugged it off as maybe they did something wrong in the application of the product.
It wasn’t until the time I rode my 1982 GPz1100 B2 model to downtown San Diego that I encountered the problems others had gone through.
After concluding my business downtown, I walked to where my bike was parked, turned the key to unlock the forks, and prepared to start the engine. The key was in the "On" position, yet I had no lights in the dash panel, the fuel pump was not running(I have FI), and the horn and tail light were not working.
Puzzled as to why nothing electrical was happening, I remember my earlier conversations about how WD-40 will over time become a non-conductor(more like an insulator). I had some pieces of 400 and 600 grit sandpaper in my tool kit and with them was able to scratch away the coating from the WD-40 on the fuses and clips.
After removing the insulating film, the bike started and ran like it should. Since that time, I’ve told people about the problem with WD-40. If you must use a contact cleaner, I recommend getting some "De-oxit" from Radio Shack Stores or any good electronic supply store.
The following user(s) said Thank You: readmckay
  • readmckay
25 Jun 2011 14:46
#459304
Awesome thank you! This is gonna be a super slow project but I have a feeling I'm going to be coming back to your post a lot! And I've been told ever since I started riding from other riders to steer clear of wd-40 on almost any part of the bike. Thanks for telling me why though! I always hate it when someone tells me something and then I ask why and they don't have an answer. Now when someone asks me, I'll have an answer :)
2007 Honda Rebel
  • MFolks
  • MFolks's Avatar
25 Jun 2011 15:53
#459313
Yes, print it out & place it in your toolbox or in a ring binder.
Here's another item:
Fuse And Fuse Holder Designations
1. The older Kawasaki’s use a glass tubed fuse with the designation of AGX 1” long. Most good auto parts stores can get them for you. They are ¼” in diameter.
2. The more common AGC is 1 ¼” long and may not fit the smaller fuse clips. Again, ¼” in diameter.
3. To clean and polish the fuse clips, I use a cotton swab(Q- Tip) and some Brasso metal cleaner or Turtle Wax Chrome Polish. I suppose any good metal polish would work.
4. These fuses can fail internally but look good, only by removing them from the clip and electrically continuity checking with either a self powered test light, or a multimeter set on OHMS can they be determined to be in good shape.
5. A physical inspection of the metal end caps for tightness will tell you if the fuse is serviceable.
6. Most modern motorcycles are now using the automobile “Blade” style fuse with the designation of ATC or ATO.
7. The reduced sized “Mini” Blade style fuse holder uses the ATM size of fuses.
8. If the fuse and fuse holder overheat, it could soften or anneal the grip of the clip, it might require squeezing the clip to restore the tightness.
9. A list of where to purchase “Blade” style fuses and holders:
www.waytekwire.com order.waytekwire.com/productdetail2/M50/...20%20%20%208%20FUSE/
www.rallylights.com www.rallylights.com/detail.aspx?ID=765
www.delcity.net/store/6!way-fuse-blocks/p_10822.a_1
10. A source for the glass tubed AGX fuses:
www.boatownerswarehouse.com/browse.cfm/2,4986.html
  • readmckay
26 Jun 2011 00:56
#459385
One day on the website and I've already got a ton of info to chew on! Thanks so much MFolks!
2007 Honda Rebel
  • Julian@MotoCARR
  • Julian@MotoCARR's Avatar
  • Automotive Afficianado
26 Jun 2011 22:54
#459568
Welcome! Free bikes are always good, regardless of condition!
Humans are smart
People are stupid
  • harm
  • harm's Avatar
  • Tom
27 Jun 2011 13:40
#459686
Welcome!! You have a lot of work to do but that will be a nice bike when your done!
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
  • readmckay
27 Jun 2011 14:05
#459699
Thanks! And I completely agree.
2007 Honda Rebel
