  • Page:
  • 1
Intake idea 23 Apr 2024 18:32 #898038
  • Adrian719
  • Adrian719's Avatar Topic Author
  • Thank you received: 3
So the filter box for my KZ440 LTD is broken. I'm thinking of building a custom intake setup and was wondering if anyone has done something similar OR has insight for my idea.
Basically I want to connect a 42mm ID silicone hose to each carburetor, with a pod filter on the end. Then I want to add a smaller "bridge" hose in between the two 42mm hoses in a sort of H shape. My logic behind it is that will help equalize the airflow/help with vacuum.
Opinions?
Intake idea 23 Apr 2024 19:37 #898040
  • TexasKZ
  • TexasKZ's Avatar
  • Away
  • Thank you received: 2089
Seems like that would add turbulence to the incoming air. Also, one filter will flow more air than a carb can use, so I do not see the advantage of adding more flow.
Intake idea 23 Apr 2024 20:37 #898042
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
Kz750 twins have a hose connecting each intake but it’s behind the carb on the cylinder head side. It’s just a hose that connect the two vacuum ports that you use for syncing the carbs.
this guy made his own air box
kzrider.com/forum/3-carburetor/599569-custom-air-box-for-kz440
Intake idea 23 Apr 2024 20:40 #898043
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2708
Back in the day, I had an XS400 Yamaha.  The stock air filters were quite expensive, so I bought two cheep uni pods, and clamped them onto the stock intake runner tubes, in a configuration much like you reference.  The bike ran fine.  Much better in fact than with the pods attached to the carbs.  That was a nightmare.
Intake idea 24 Apr 2024 04:39 #898052
  • Adrian719
I was thinking it would help with the whole vacuum issue people talk about. Good point about the filters allowing to much air though. Maybe I can come up with some sort of Y pipe instead.
Intake idea 24 Apr 2024 04:39 #898053
  • Adrian719
Ahh that's very interesting. Its too bad these CV36 carbs don't have that option otherwise that would make this super simple.
I did see that airbox post, pretty neat. I just want something even simpler/lighter.
Intake idea 24 Apr 2024 04:40 #898054
  • Adrian719
Yeah basically from what I'm seeing the CV36 carbs need that intake runner spacing to work properly. I guess it just comes down to needing the bridging hose or not.
Intake idea 24 Apr 2024 05:18 #898058
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1898
My personal opinion is that the bridging hose is an unnecessary complication with no tangible benfit
The following user(s) said Thank You: Adrian719
Intake idea 24 Apr 2024 08:11 #898068
  • F64
  • F64's Avatar
  • 81-KZ440D2
  • Thank you received: 357
Try it out. Take notes.
Change the pipe size. Take notes.
Remember, the carbs don't just suck. They blow too.
I used an oscilloscope to balance my carbs 2 weeks ago.
The pulses at the carburetor look like a sawtooth pattern.
Alternating between vacuum and pressure.
I guess i should put the pressure sensor in the airbox to see what the pressure/vacuum looks like on this side of the carb.
It's probably more subdued as it's a larger mass of air.
More testing I guess.
81-KZ440-D2.
LIC, NY
The following user(s) said Thank You: sf4t7, Adrian719
Last edit: by F64.
Intake idea 24 Apr 2024 09:38 #898070
  • Adrian719
Now that is some quality data
Intake idea 24 Apr 2024 13:25 #898080
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 384
Just to add more info for those interested, I have found this article of interest. It addresses both intake and exhaust modifications and how some improve things and how some do not. I am not claiming it is the end all for either intake or exhaust changes but rather I found it of interest.
bmwmotorcycletech.info/InExTuning.htm
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
Intake idea 24 Apr 2024 13:31 #898081
  • Nessism
  • Nessism's Avatar
Below is the XS400 Yamaha airbox runner configuration.  Other than length of the runners, very similar to what the OP is proposing...
  • Page:
  • 1
