Piston Hole Kz1000LTD 1982 05 Jan 2023 00:24 #878543
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1953
Given what was done to the top yolk the PO was an "animal" who obviously abused this bike until it wouldn't run any longer, nice to see it being saved
The following user(s) said Thank You: cartal, hardrockminer
Piston Hole Kz1000LTD 1982 05 Jan 2023 01:25 #878544
  • cartal
  • cartal's Avatar Topic Author
  • Thank you received: 69
Yes. A really abused bike in the past.
New carb boots, new carb internals, new air filter (new cap and funnel that were missing), and ngk right plugs are already waiting.
will take the head for new valves to a reputable shop and of course new valve seals. Head will be checked and skimmed if needed.
have already eyed some +0,50 pistons and will have the cylinders bored.will take The pan off for a check. I like the gas oil flush idea.
cheers
Piston Hole Kz1000LTD 1982 05 Jan 2023 05:49 #878545
  • cartal
Hello,
I´ve found this piston set at IMD Pistons in the UK. They have a lot of excellent opinions. I assume this is the kit for my "J" engine.
imdpistons.com/products/kawasaki-kz1000-csr-998cc-piston-kit
See some pics. Total dissasembly (pistons came out fairly easily). Some details on valve seats that will be done by a reputable shop. New valves and seals will also come in. There is also a pic from the underside of the piston with a hole. There is a little material projection to the underside, but the crank area right below was absolutely spotless.
I have no clue (although I believe so) if my pistons are standard. Can someone guide me here by taking a look at the markings inside the pics?
If they are standard, I should be OK with these pistons from IMD. They are a +0,50 oversize. I will of course get the cylinder block bored.
Thanks a ton.
Carlos
Last edit: by cartal. Reason: forgot a link!
Piston Hole Kz1000LTD 1982 05 Jan 2023 05:55 #878546
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
You would be best to carefully clean one of the piston crowns as this is where any oversize is marked (ref the below) and to be "belt and braces" you can measure them with a verier against the spec in the manual (I believe stock is 70mm in a "J" motor)
Last edit: by Wookie58.
Piston Hole Kz1000LTD 1982 05 Jan 2023 06:28 #878547
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 689
J is 69.4 bore.
Z1000J2 somewhat modified!
The following user(s) said Thank You: cartal, Wookie58
Piston Hole Kz1000LTD 1982 05 Jan 2023 06:37 #878548
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1937
The KAWASAKI Z1000J standart bore diameter is 69,40 mm (998 ccm), Early KZ1000 is 70,00 mm (1015 ccm)
Over bore pistons are available in  + 0,35 / 0,50 / 0,85 / 1,00 mm
www.scheuerlein-motorentechnik.de/motorr...1000-modelle/z1000j/
Edit:
Warren3200gt  was faster
The following user(s) said Thank You: cartal, Warren3200gt, Wookie58
Last edit: by Scirocco.
Piston Hole Kz1000LTD 1982 05 Jan 2023 06:55 #878549
  • cartal
Will check with this info. You guys rock!
Piston Hole Kz1000LTD 1982 05 Jan 2023 07:08 #878550
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
Just one big happy family Carlos
Piston Hole Kz1000LTD 1982 05 Jan 2023 08:47 #878552
  • ronnieV
  • ronnieV's Avatar
  • Thank you received: 300
Carlos,I hope you choose to donate on a regular basis,as you can see these guys know there shit.Wealth of information is here for the asking.
The following user(s) said Thank You: sf4t7, cartal
Piston Hole Kz1000LTD 1982 05 Jan 2023 09:27 #878553
  • cartal
Wow… pistons clean up really well with wire wheel.
yep. Standard measure no markings
Piston Hole Kz1000LTD 1982 05 Jan 2023 09:31 #878554
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
Look like "stock" to me, a set of +0.5's and a "head job" she should be fresh as a daisy
Piston Hole Kz1000LTD 1982 05 Jan 2023 09:38 #878556
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1490
Pistons are stock.
Exhaust seats look like they've been run with insufficient valve clearance.
If you take the head to a shop make sure they know what they are doing with bucket and shim motors when they cut the seats.
