martin_csr wrote: In two years you haven't splashed any fuel on it? ... not even a smidge? WOW.
I get paranoid at gas stations.
But yes, I hang the fuel filler to let all of the drops shake off before I try to put it near the tank, then I wait a long time after it full before I remove the filler. That last drop seems to hang there forever.
While filling, there is a tiny bit of spray that gets on the tank, but it seems to evaporate before having any effect.
My other bike that was sprayed 15 years ago with Du Pont lacquer gets occasional spillage and seems fine (though I wipe it immediately if it does get spill). That tank I allowed to cure for several months before using machine glaze and a good wax job.
The bike in my avatar is factory paint from 81. It actually has stains from spills that were there before I bought it. I was surprised to see the stains on the factory paint. I haven't tried to buff it out as it is covering the stripes, and I don't know how thick the clear is. It only shows up in certain lighting angles.
