How to remove rust from tank 05 Oct 2015 16:31 #693508
  • kz n az
  • kz n az's Avatar Topic Author
  • Thank you received: 8
I checkout the tect-tips on the forum here about rust removal but was wondering, do you agree. Or is there a better way ( no disrespect to the person ) This was a problem before and its back and what would you seal it with.
THANKS EVERYONE.
Thanks Everyone. I believe I will remove the rust and try not sealing it. But will keep a close eye on it.
THX. Jim
Last edit: by kz n az.
How to remove rust from tank 05 Oct 2015 16:37 #693509
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2644
How much rust and what are you talking about?
How to remove rust from tank 05 Oct 2015 16:41 #693511
  • kz n az
really not to bad nothing deep if that what yiu mean
How to remove rust from tank 05 Oct 2015 16:47 #693512
  • Thank you received: 2829
After the rust is removed you should not need to seal it. All you need to do is keep fuel in the tank and it won't rust. Rust happens when the tank is left empty or partially empty because moisture and condensation collect on the inside and form rust. That doesn't happen if fuel is in the tank instead of air. Ed
How to remove rust from tank 05 Oct 2015 16:48 #693513
  • SWest
  • SWest's Avatar
  • 10 22 2014
Copy and paste the page.
How to remove rust from tank 05 Oct 2015 16:54 #693515
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2707
I've done a lot of tank cleaning and lining and like to use phosphoric acid to derust. Home Depot sells Kleenstrip Etch n Prep for about $14/gallon. Be sure to remove all petcock, sending unit, etc., before derusing. Rinse well with water and use some alcohol or WD-40 immediately after rinsing to retard flash rusting.
How to remove rust from tank 05 Oct 2015 18:09 #693525
  • jackleberry
  • jackleberry's Avatar
  • Thank you received: 56
Evaporust!
1997 KZ1000P (P16)
2001 KZ1000P (P20)
How to remove rust from tank 05 Oct 2015 18:19 #693526
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Thank you received: 1282
kz n az wrote: I checkout the tect-tips on the forum here about rust removal but was wondering, do you agree. Or is there a better way ( no disrespect to the person ) This was a problem before and its back and what would you seal it with.
THANKS EVERYONE.
No there is no better way. But then I'm NOT impartial. As Ed said there's no need to seal the tank, just keep it full.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: by KZQ.
How to remove rust from tank 06 Oct 2015 01:32 #693539
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 381
I've used the electrolysis method on a XS650 tank that I thought was too far gone. Came out like new!
As for tank liners, I use Red Kote on anything questionable especially if I am going to be investing in paint.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
How to remove rust from tank 06 Oct 2015 13:26 #693599
  • bountyhunter
  • bountyhunter's Avatar
  • Thank you received: 337
kz n az wrote: really not to bad nothing deep if that what yiu mean
Dumb question: rust on outside or inside? I'm an old body man and I thought you meant rust on the outside.
How to remove rust from tank 07 Oct 2015 06:16 #693648
  • davido
  • davido's Avatar
  • Thank you received: 286
I used brown vinegar. Very cheap and it works a treat.I soaked it for a couple of weeks then rinsed it out with soda,dried it and gave it a misting with WD40 to stop the flash rust. Came out great.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
How to remove rust from tank 07 Oct 2015 07:52 #693660
  • MDZ1rider
  • MDZ1rider's Avatar
  • Thank you received: 118
I vote with Jackelberry. Evaporust is the best thing I've ever used. It's not acid based and does not harm paint. It also requires no agitation. Just pour it in and let it sit over night. Unfortunately it's also expensive. You'll need at least 2 gallons at appox. $25.00 each. However, it can be reused. I've used the same batch on 3 tanks so far. I figure I'm now down to $15 per tank.
