  • Page:
  • 1
1980 KZ 440 engine sprocket 03 Mar 2024 11:20 #895887
  • stepkitto
  • stepkitto's Avatar Topic Author
  • Thank you received: 2
I am trying to replace the engine sprocket on my 1980 KZ 440 A1.  I am not sure of the thread direction since the nut on the shaft will not budge.  I am assuming that it has right hand threads.  I sprayed it with WD 40 and let it sit overnight.  I used an impact driver but still no budge and I am afraid to break it.  Any suggestions would be appreciated !  Thanks!
1980 KZ 440 engine sprocket 03 Mar 2024 13:26 #895890
  • ckahleer
  • ckahleer's Avatar
  • Thank you received: 133
When you say Impact driver, do you mean the type impact wrench used for removing car lug nuts? I'm suprised that wouldn't do it.
You could try tightening it to break it loose. Or heat it with a tourch. If you have to split it to get it off, new nuts are avalible.
I'm 90% sure it is RH threads
94 KE100
81 CM200t
82 KZ305
79 KZ400
85 VT 500c
85 VF1100c
The following user(s) said Thank You: stepkitto
1980 KZ 440 engine sprocket 03 Mar 2024 13:33 #895891
  • stepkitto
Yes. air powered impact wrench.  Maybe use a big nut splitter ?
1980 KZ 440 engine sprocket 03 Mar 2024 15:26 #895898
  • Wookie58
  • Wookie58's Avatar
  • Online
  • Moderator
  • Thank you received: 1789
If you use heat be prepared to replace the seal behind it once off if necessary - rubber doesn't like heat
Might seem like a stupid question but I assume you have released the locking washer ?
Last edit: by Wookie58.
1980 KZ 440 engine sprocket 03 Mar 2024 17:44 #895911
  • Nerdy
  • Nerdy's Avatar
  • Thank you received: 379
I recommend using a proper penetrant like Kroil or PB Blaster. WD-40 isn't going to get the job done (if that is indeed the issue).
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
1980 KZ 440 engine sprocket 03 Mar 2024 17:48 #895912
  • Nerdy
  • Nerdy's Avatar
I thought there would be a locking washer (the kind with the bend-up edge) but Partzilla says there isn't one - unless the spline washer is meant for that. The diagram shows a strange cutout in the side of the spline washer, so maybe that's it.
www.partzilla.com/catalog/kawasaki/motor...1/transmission-80-a1
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
1980 KZ 440 engine sprocket 04 Mar 2024 05:34 #895932
  • stepkitto
Yes. there appears to be a bent flap on the washer behind the nut.  I did bend it down.  I will try a better penetrant fluid and let it sit overnight.  I will try again to break it loose with the air wrench.
1980 KZ 440 engine sprocket 04 Mar 2024 05:38 #895934
  • Wookie58
  • Wookie58's Avatar
  • Online
  • Moderator
Worth checking the "tab washer" is bent back far enough
1980 KZ 440 engine sprocket 04 Mar 2024 06:36 #895940
  • Nerdy
  • Nerdy's Avatar
Definitely - the washer can interfere even if it appears to be out of the way. Recommend using a drift punch to ensure the washer is 100% clear, especially where it contacts the nut. Simply using a chisel or similar to bend the tab back down will likely leave a small bump that will hold the nut in place.
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
1980 KZ 440 engine sprocket 06 Mar 2024 11:49 #896054
  • stepkitto
Hurrah !  I got the nut to come off today.  2 days of soaking with JB 80 and a friends Dewalt 20v impact wrench.   Actually, it came off pretty quick with the Dewalt.  For future reference it has right hand threads.  A BIG THANK YOU to All for the advice and encouragement!  Cheers !
The following user(s) said Thank You: Nerdy
1980 KZ 440 engine sprocket 06 Mar 2024 14:29 #896060
  • Nerdy
  • Nerdy's Avatar
Outstanding - thanks for the update!
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
  • Page:
  • 1
