  • Page:
  • 1
  • 2
Front left frame welded by previous owner 22 Jul 2023 15:46 #887499
  • Tjpgi
  • Tjpgi's Avatar Topic Author
  • Thank you received: 1
I purchased this KZ900 4A in1980 form a warehouse where the bike was sold to the warehouse owner. I bought it from him for a few hundred $. It wasn't running and obvious it had sustained
front end damage. I fixed it and drove it periodically over the last 43 years. I'm looking to sell it and wondered if there are motorcycle frame experts that could evaluate the welds and alignment of the frame to see if they are satisfactory. I have had no problems and the weld remains intact over the decades. It is quite obvious and I would disclose it anyway to a potential buyer. Or should I not bother and list it at a reduced price and see if anyone wants it with the welded frame. See attached pix.
Thanks
Tom
Last edit: by Street Fighter LTD.
Front left frame welded by previous owner 22 Jul 2023 17:47 #887500
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2644
Pics would help
The following user(s) said Thank You: Tjpgi
Front left frame welded by previous owner 22 Jul 2023 18:14 #887501
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1043
There are specialist welding engineers out there.  If you've ridden the bike for 43 yrs and are still alive I suspect the frame is fine.  Unless you know of a problem you can always sell it as is.
For interest sake, I bought a Z1B with a serious frame crack on the left downtube.  I had it repaired and eventually sold the bike.  If done properly the tube won't show any weld and it will be as good as new.
Last edit: by hardrockminer.
76 KZ 900 frame repair or replace or sell as is 22 Jul 2023 19:27 #887503
  • Tjpgi
Thanks
Tom
76 KZ 900 frame repair or replace or sell as is 23 Jul 2023 06:51 #887509
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1990
I merged your threads into one  AND  fixed your pictures in your last post to be full size .
Next time when posting pictures  finish the install by clicking  insert all , then submit and pictures will be full size .
I also deleted a third thread which you posted as it was just a duplicate  of the first one .
Welcome to KZR
 My 2 cts  is sell it as is so the next owner will see what has happened , and what needs to be done to fix it
76 KZ 900 frame repair or replace or sell as is 23 Jul 2023 06:52 #887510
  • Nebr_Rex
  • Nebr_Rex's Avatar
  • Thank you received: 298
Honesty is the best policey.
It is out in the open and should be obvious to any would be buyer.
That being said, the weld of that quality even if it holds will affect the value of the bike.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
76 KZ 900 frame repair or replace or sell as is 23 Jul 2023 06:56 #887511
  • Nebr_Rex
  • Nebr_Rex's Avatar
And taking a second look it seems to have been stick welded with small rod, 3/32 or 1/16.
Also the tubes are not alined.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
76 KZ 900 frame repair or replace or sell as is 23 Jul 2023 07:06 #887512
  • Moderator
I didn't want to pick on  a new member seeking  advise here , But If  no one in his area can do a proper job , then I would sell it as is .
The work needs to go back to square one  and  be  done again .
Front left frame welded by previous owner 23 Jul 2023 09:00 #887513
  • sf4t7
  • sf4t7's Avatar
Just be honest with any potential buyer and give them the same history and information you gave us.
Scotty
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
76 KZ 900 frame repair or replace or sell as is 23 Jul 2023 10:24 #887514
  • Tjpgi
Thanks for the input. You are absolutely right about the misalignment of the front tube. I would actually like to spruce up the bike a bit and keep it, but the wife suggested otherwise since we have quite a few toys (I call them tools). I'll call around to some custom bike shops and see what I can find. What kind of price range are these bikes bring (ones without frame damage and in average cosmetic but runs and shifts good)?
Thanks again to all for your input.
Tom
76 KZ 900 frame repair or replace or sell as is 23 Jul 2023 11:20 #887516
  • Moderator
How about pictures of the whole bike and a list of accesories and work done to it
 Then we can help with a value
76 KZ 900 frame repair or replace or sell as is 23 Jul 2023 15:06 #887518
  • Tjpgi
Carbs and tank are off the bike for a carb rebuild. Will post a picture once all put back together The bike is stock 76 KZ900.
Thanks
  • Page:
  • 1
  • 2
