  • Page:
  • 1
1977 replacement frame 20 Oct 2020 12:12 #837308
  • KZGRATEFUL
  • KZGRATEFUL's Avatar Topic Author
  • Thank you received: 0
undefined Good afternoon, I recently obtained what appears to be a replacement frame for 1977kz1000A part# 32002-157. Made in Japan is stamped on the neck. No serial #'s nor sticker. There does not appear to have been any tampering involving removal of a previous Vin ID. Anyone ever run across this "replacement" part before? Or know if the serial #'s from a damaged frame (if destroyed) can be legally stamped onto the neck? Grateful for any guidance i can glean. Many thanks
1977 replacement frame 20 Oct 2020 14:06 #837314
  • 73z1
  • 73z1's Avatar
  • Thank you received: 103
I had a 73 Z1 with replacement frame and no vin.
Sometimes dealer stamps vin, sometimes they do not.
Replacement frames are rare.
The following user(s) said Thank You: KZGRATEFUL
1977 replacement frame 20 Oct 2020 14:06 #837315
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1481
Yes ! Replacement unstamped frames were not uncommon.
Stamping on the number from an existing damaged frame isn't legal but if you did real a neat good job, destroy the original and keep it to yourself who would know.. :whistle:
Last edit: by zed1015.
1977 replacement frame 20 Oct 2020 14:48 #837318
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
  • Thank you received: 270
Well, I for one, wouldn't know! :laugh:
Wife's little bike... 1984 GPZ 550 Kerker and DynaJet stage I kit
Wife's BIG bike...... 1981 GPZ 1100 Kerker and factory FI Mikuni RS34s W/ K&N pods
1977 replacement frame 20 Oct 2020 15:08 #837323
  • KZGRATEFUL
Thank you for the replies : ) Makes one wonder what the use of a replacement frame is if can not legally be used. Grateful
1977 replacement frame 20 Oct 2020 21:17 #837348
  • krazee1
  • krazee1's Avatar
  • Thank you received: 198
Service part frames are definitely not common, possibly because they were always a relatively expensive part. As far as restamping the V.I.N., that is what they were made for, as in replacement frame!
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
1977 replacement frame 21 Oct 2020 05:10 #837362
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
You have to remember that different States have different ways of dealing with things like this. In my home state at one time the State Patrol would actually stamp in a VIN once they had verified the frame replacement was legally done. If it was a frame replacement for a non-existing frame the State DOT would issue a "Wis" number that would be stamped on the frame, but this created all sorts of problems for resale, or even if you rode the bike out of state and were stopped. Especially if you went to a big bike event. Manually stamped in numbers never looked right and my advice was to always carry copies of the DOT documents with you just in case your were stopped. I have been out of the loop with this stuff for several years so they could be doing things differently today, so it would be good to check first. Before I retired we were trying to get DOT to issue a tamper proof tag with the VIN number stamped on it that could be affixed to the frame, but I don't know if that was ever done.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
The following user(s) said Thank You: DOHC, KZGRATEFUL
1977 replacement frame 21 Oct 2020 05:50 #837365
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2091
Definitely check with your local DMV. I have heard of cases where the engine number rather than the frame number was used for registration.
1977 replacement frame 21 Oct 2020 06:44 #837371
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1883
My 1978 LTD 1000 is a State of Michigan issued frame. The vin is “michxxxx”. It wasn’t a factor 35 years ago. I had it titled in my name and insured. But after sitting and not insured for so long, about 4 years ago when I tried to insure it it turned into a PITA. Even though I had a 25 year old expired insurance certificate and a title in my name, I had several motorcycle specific insurance companies refuse to insure it. Finally found a local company that covered it for me... About 6 months ago I bought a 1978 LTD frame that has been powder coated and waiting for me to get up the enthusiasm to swap out the frame. I assume mine was totaled and scrapped, the front end isn’t correct but everything else is. Again I assume that someone purchased it from the title company and rebuilt it... the title actually says make-Kawasaki, model-assembled.
1977 replacement frame 21 Oct 2020 13:45 #837401
  • KZGRATEFUL
KZ Riders, I really appreciate all the feedback. Learning from the trials of others is a tremendous resource. Be well
1977 replacement frame 17 Feb 2024 12:11 #895360
  • increasing
  • increasing's Avatar
  • "curious to know"
If you do this together with your land vehicle authority, the old damaged frame's VIN number will be checked and then stamped onto the new frame. The damaged frame is then condemned or used as parts and the new frame can be used but receives a note in the vehicle registration that the frame has been replaced on this motorcycle.
increasing :)
1976 Kawasaki KZ900-A4 & 1974 Kawasaki Z1A 900
  • Page:
  • 1
