Shinko tire 31 Dec 2016 14:28 #751023
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2629
Decided to start my own thread on the subject. Uploading the clips in parts.
Shinko tire 31 Dec 2016 16:45 #751027
  • SWest
  • 10 22 2014
Part two.
Shinko tire 31 Dec 2016 18:11 #751033
  • SWest
  • 10 22 2014
I'm going to upload the rest and put them in one post. Kinda hard to believe I made money doing this but that was 30 years ago too. :dry:
Shinko tire 01 Jan 2017 08:27 #751064
  • SWest
  • 10 22 2014
"The rest of the story." B)
Last edit: by SWest.
Shinko tire 01 Jan 2017 08:52 #751066
  • SWest
  • 10 22 2014
If I can't fit my tire, I'll have to stop riding. What happens if I have a flat on the road?
Shinko tire 01 Jan 2017 14:02 #751100
  • Thank you received: 2829
swest wrote: If I can't fit my tire, I'll have to stop riding. What happens if I have a flat on the road?
Same here. I've been fitting my own tires since I bought my first bike 51 (egads!) years ago. I estimate I have changed more than 30 tires, and I usually don't have a great deal of trouble although I never really look forward to doing it.
I did have one tough problem removing an old Michelin tire; the bead simply would NOT break no matter how many C-clamps, breaker bars, hammers, creative language, etc. I used. That puppy was REALLY stuck to the rim. Finally I decided to try something totally different. I took a box knife and cut both sidewalls all the way around parallel and close to the rim. That allowed me to easily remove the tread section along with most of both sidewalls. It left nothing much more than both beads left on the rim. Much to my surprise, I was then able to remove both beads with almost no trouble at all since the tire wasn't holding them against the rim. Ed
The following user(s) said Thank You: JR, SWest
Shinko tire 01 Jan 2017 14:57 #751105
  • SWest
  • 10 22 2014
That 15 year old Chin Shin tire on Bossie was a bear to get off. Almost took my Saws All to it. :angry:
Shinko tire 01 Jan 2017 21:19 #751142
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
Because in 49 years of riding, I've only had two flat tires.... and both the rear tire.... I'll just pay the $25 for R&R (with balance) that is charged around here.
One of those flats was a slow leak from small drywall nail in my 71' Triumph Trident... no big deal and I just paid a guy to pull the tube out half way through the side wall and rim... basically fixed the inner tube with a patch.
However the one bad one happened 4-5 miles from home and it was a 3"L x 3/8" dia lag screw and it went right through and out the side wall on the KZ1000. That was a new tire and tube change which set me back $130.00. OUCH
But I was still able to walk the bike home with the engine running at idle and sliding the clutch in and out while mostly walking along side it... LOL... yeah, I cheated a couple times, sat on it and wobbled on it for a qtr mile or two when tired.
That's it.... and regardless, I'm still gonna ride and still gonna pull the wheel and take it in to pay the $25.00! LOL
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: by missionkz.
Shinko tire 01 Jan 2017 21:31 #751144
  • SWest
  • 10 22 2014
Rear flats at speed can throw you down. :ohmy: I highly suggest a new tube each time. This is my third tire with this tube. I don like it. :pinch: The reason I used the mallet at the end is that's the time when the spoon can be dragged into the rim with the tire causing a pinched tube.
I had a bad one on my 350 Honda on the 10 with my chick on the back. Went from the fast lane to the shoulder and back in seconds. HAIRY. Broke a spoke.
DAMN I miss my Lesters. I'd have to use leather protectors though. :whistle:
Shinko tire 02 Jan 2017 04:58 #751146
  • rrsmsw9999
  • rrsmsw9999's Avatar
  • Thank you received: 67
Hey Steve, They are a bit pricey, No-Mar tire spoons are the best I have found for the price and with 3 of em you can do any tire with spoons from the road or floor. :) Not mount or demount bar needed. R
Attachment NoMar.jpg not found
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Shinko tire 02 Jan 2017 06:09 #751150
  • riturbo
  • riturbo's Avatar
  • Thank you received: 277
So you dont balance them ??
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Shinko tire 02 Jan 2017 06:31 #751151
  • SWest
  • 10 22 2014
I ran without balance more often than not. Went through tires too fast. Now I take that extra step. The last tire I had six weights opposite of the stem. This time I took them off one by one and then added one next to the stem so I have one 180* from it and one next to it. I don't understand it. :unsure:
