  • Page:
  • 1
  • 2
Throttle real stiff 25 Jul 2016 22:39 #736219
  • EDD88
  • EDD88's Avatar Topic Author
  • Thank you received: 0
I apologize in advance if this is in the wrong place.
The throttle on my '81 kz750e is super stiff and I was wondering if there is a way to fix that? Friend of mine said maybe just a squirt of wd40 might fix it or to just get a new twist.
Being my first bike I don't wanna screw anything up so any advice is welcomed
Eddie
Throttle real stiff 26 Jul 2016 01:16 #736223
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
I'd loosen the throttle tube from the bars, slide it away and see if the bar end or tube iis gritty bone dry inside. If not then disconnect the cable(s) from the carbs and see if the throttle slides are stiff and at the same time see if the throttle tube rotates easier or the same now disconnected from the carbs.
If the the carbs slides are stiff, carb cleaner sprayed in there can usually loosen them if it is gas varnish deposits.
If all fails, you might have dry throttle cable and it can be soaked in thin oil to lube it, $15-$20 usually buys you a new one.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: by missionkz.
Throttle real stiff 26 Jul 2016 05:21 #736230
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1624
Is the bike basically stock or has it been bobbered or something?
I would clean & lubricate the throttle & cable, especially the cable ends. This is normal maintenance & should not be neglected. To lube the cable ends I use permatex brake caliper grease in the little packets. If it's still stiff, I guess the next thing would be to check the carburetors. The 750E has butterfly valves that open & close. Also, try turning the handlebars side to side while twisting the throttle to see if that makes any difference, in case the throttle cable is binding.
Last edit: by martin_csr.
Throttle real stiff 26 Jul 2016 06:46 #736241
  • Thank you received: 2829
Missionkz's advice should be followed. "disconnect the cable(s) from the carbs and see if the throttle slides are stiff and at the same time see if the throttle tube rotates easier or the same now disconnected from the carbs."
This will tell you if the problem is throttle cable/throttle tube related. If so, clean and lube the throttle tube / handlebar area and lube the throttle cables. Also, ensure the throttle cables are routed correctly. If they are not they can bind. Ed
Throttle real stiff 26 Jul 2016 08:04 #736245
  • TexasKZ
  • TexasKZ's Avatar
  • Away
  • Thank you received: 2074
The Motion Pro luber will make the job MUCH easier and less messy
www.motorcycle-superstore.com/4838/i/motion-pro-cable-luber
Plus---
Last edit: by TexasKZ.
Throttle real stiff 26 Jul 2016 08:06 #736248
  • EDD88
Awesome thanks guys. I'm on the road right now but as soon as I get some home time I'll deffinetly check all that stuff out.
Its all stock as far as I know except a fat bob tank, Springer seat and screaming eagle exhaust tips. All of that was done by a previous owner.
Eddie
Throttle real stiff 26 Jul 2016 08:35 #736257
  • Thank you received: 2098
Cable luber is readily available and relatively inexpensive to do a quick thorough job on any cable.
Enables quickly blasting lube throughout the entire length of the cable without having to rely on gravity flow from a pooled source as described in many service manuals.
Good Fortune! :)
Last edit: by Patton.
Throttle real stiff 26 Jul 2016 09:52 #736275
  • martin_csr
If you have a funnel & various sizes of tubing laying around, you can make a cable luber.
fit one section of tubing over the outer sheathing & another section or two over that, then attach the funnel & spray.
you may have to slit the first section of tubing down its length. I hang mine from the eaves w a couple of coat hangers
& use masking tape to hold it together. kinda red-necky but it works. :blush: :laugh:
ps: I asked about the bike being stock, because sometimes the throttle cables are wrong when the bars are changed out.
Throttle real stiff 26 Jul 2016 10:27 #736282
The little cable luber is available in several different colors, including various shades of red. :lol: :lol: :lol:
Click here > Cable Luber available in different colors from Amazon
Good Fortune! :)
Throttle real stiff 26 Jul 2016 11:58 #736293
  • EDD88
Thanks guys I'll grab some of that stuff as soon as I get home!! Stuff like that should be available at a local motorcycle dealer or shop right?
Eddie
Throttle real stiff 26 Jul 2016 15:38 #736317
  • missionkz
EDD88 wrote: Thanks guys I'll grab some of that stuff as soon as I get home!! Stuff like that should be available at a local motorcycle dealer or shop right?
Eddie
Probably yes, especially if they sell dirt bikes!!
Bruce
1977 KZ1000A1
The following user(s) said Thank You: EDD88
Throttle real stiff 27 Jul 2016 04:46 #736355
  • riturbo
  • riturbo's Avatar
  • Thank you received: 277
I would do the clutch cable while your at it .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • Page:
  • 1
  • 2
