  • Page:
  • 1
Gas tank bolt? 30 Jul 2015 21:44 #683556
  • theleonard
  • theleonard's Avatar Topic Author
  • Thank you received: 0
After riding my new-to-me KZ400 home tonight, I learned that nothing but gravity and the front of the seat were holding the tank on. Does anyone know the part number for that bolt, or a suggestion for a good replacement? I had no luck searching the forum, and the resolution on the old parts catalogs online is too low to zoom in on the part number.
2002 DL1000
1979 KZ400
Gas tank bolt? 30 Jul 2015 22:05 #683559
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
www.bikebandit.com/oem-parts/1979-kawasa...nk/o/m150611sch82745
is that what you have? 79 400B use the slider to enlarge the pic and mouse the image to where you want it. Looks like a push fit onto a rubber damper like the 550 and 1100, can't see any bolt.
Gas tank bolt? 31 Jul 2015 05:26 #683574
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1624
Kawasaki.com -->> 1979 KZ400-H1 -->> fuel tank bolt = 92001-1284 = 6x25
There's also a washer, a collar & a couple of dampers --- in case anything else is missing.
The following user(s) said Thank You: theleonard
Last edit: by martin_csr.
Gas tank bolt? 31 Jul 2015 15:39 #683643
  • jakedude
  • jakedude's Avatar
  • Thank you received: 30
If it is just a bolt, go to a hardware store. Ace Hardware will have one.
Nothing lasts, nothing is finished, and nothing is perfect.
Gas tank bolt? 31 Jul 2015 15:57 #683645
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2629
It should have a rubber dampener.
Gas tank bolt? 31 Jul 2015 16:44 #683658
  • theleonard
Perfect. Your info helped me find a replacement quickly. I toyed with the idea of just grabbing a replacement from the hardware store, but I'm not as good at sizing them as I'd like to be.
2002 DL1000
1979 KZ400
Last edit: by theleonard.
  • Page:
  • 1
