here is a start:
Got it home, swapped the battery.
Checked lights. Everything good (quick test on wiring.)
next, examine the air filter. I find a mouse nest, complete with a piece of rat poison... Not a good find, however, no penetration into the air filter, they just used the box...
Clear rat nest, and attempt to start so I can hear what is going on.
Here is what I hear: poor attempt to turn over, then click click click. I listen to the click to see it is at the starter solenoid, then try again, and here it at the starter as well. Good sign, in a way. To me, the untrained bike guy, it appears that those are good and well. now to remove the side cover (starter cover removed to view starter.)
Another issue... gas leaking both from the right side carburetor and the little "overflow" hose...
~ Upon disassembly of the carburetors, I notice a screw is missing from the float bowl. This screw has been broken off... nice present.
Clearly, at least it appears so to me, it is time to rebuild some carbs.
Pictures to be added later, because I dislike samsungs new attach a phone weird program thing.
I shall be telling this with a sigh
Somewhere ages and ages hence:
Two roads diverged in a wood, and I—
I took the one less traveled by,
And that has made all the difference.
~Robert Frost
