I think I need a new voltage regulator. 04 Jul 2016 11:30 #733815
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2707
GPzMOD750 wrote: I've checked every wire In every way possible. And have it hooked as shown. I would suspect the stator if I wasn't getting a charge with the old R/R. I do have another stator but the bench test for the SH775 failed.
Like I said. I sent the seller a message, They have about a half dozen more listed so let's see if they send me another.
What voltage do you get with the old R/R at 5000 rpm?
I think I need a new voltage regulator. 04 Jul 2016 11:43 #733817
  • GPzMOD750
  • GPzMOD750's Avatar Topic Author
  • Thank you received: 148
[quote="Nessism" post=733815
What voltage do you get with the old R/R at 5000 rpm?[/quote]
Anything above idle I'm getting approx 12.5v +/- .20v regardless of rpm. I know I should be getting at least 13.5v but at least it's a charge. This is after having to use my battery charger to start the bike since the battery is getting below 10v since the SH775 isn't working AND I'm chasing headlight circuit gremlins some more.
I think I need a new voltage regulator. 04 Jul 2016 11:43 #733818
  • GPzMOD750
Nessism wrote: What voltage do you get with the old R/R at 5000 rpm?
I think I need a new voltage regulator. 04 Jul 2016 11:57 #733819
  • Nessism
  • Nessism's Avatar
  • Away
I wouldn't be so quick to blame the SH775. Your stator is dead. Get a new one and then go from there. Bet you the SH775 will work fine with a good stator plugged in.
I think I need a new voltage regulator. 04 Jul 2016 12:49 #733827
  • GPzMOD750
Nessism wrote: I wouldn't be so quick to blame the SH775. Your stator is dead. Get a new one and then go from there. Bet you the SH775 will work fine with a good stator plugged in.
I swapped stators. Yeah, that was fun.
Same results, so I either have 2 bad stators or 2 bad R/Rs or both.
I think I need a new voltage regulator. 04 Jul 2016 12:54 #733828
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2643
On my bike there are three yellow wires. You test between each and should have 50+/- VAC. If there's less that 49 VAC the stator is weak or bad.
I think I need a new voltage regulator. 04 Jul 2016 13:05 #733831
  • GPzMOD750
swest wrote: On my bike there are three yellow wires. You test between each and should have 50+/- VAC. If there's less that 49 VAC the stator is weak or bad.
Just to clarify.
While the bile is running? 50 volts, AC between any 2 of the 3 wires tested in every combination?
Last edit: by GPzMOD750.
I think I need a new voltage regulator. 04 Jul 2016 13:08 #733832
  • SWest
  • SWest's Avatar
  • 10 22 2014
Yes.
I think I need a new voltage regulator. 04 Jul 2016 13:18 #733836
  • GPzMOD750
Got it! After my best break, maybe.
I think I need a new voltage regulator. 04 Jul 2016 13:45 #733842
  • Nessism
  • Nessism's Avatar
  • Away
To do that no load test you need to disconnect the stator entirely and rev the engine to 5000 rpm or more. Set your meter to AC voltage too. Oh, and make that 75 volts AC, not 50. And even if you get good voltage that doesn't mean your stator is at full power. I've seen 75 volts before and the best the charging system would do is 13.7 volts.
I think I need a new voltage regulator. 04 Jul 2016 13:50 #733844
  • SWest
  • SWest's Avatar
  • 10 22 2014
<ime will do that with all lights on, then goes up to 14.5 when the battery is fully charged.
I think I need a new voltage regulator. 04 Jul 2016 14:08 #733845
  • GPzMOD750
OK, I did a test got ~55v AC. One thing I realized is that I had the stator wires to the regulator hooked up wrong.
The factory connector is a six pin connector 2x3. There are only 5 wires to hook up. The bottom 3 are the stator the one top outside is the ground the other top outside is the hot. Guess how I had it hooked up? I had the stator wires hooked up to the top 3, stupid mistake. So if this R/R is toast it's probably my fault.
I hooked it up correctly and the voltage slowly rose from where it started at about 11v. I disconnected the stator wires, did the AC test, After that I checked my voltage at the battery and it was just over 9V. I hooked up the stator wires again and at Idle it slowly rose starting at about 11.5v I reved to 5k and it got to about 12.5 volt and held steady until I shut things down.
I put the battery charger on it and I'll check it again later.
