regulator prob 26 Sep 2015 13:56 #692042
  • goldylox
  • goldylox's Avatar Topic Author
  • Thank you received: 0
I have a 1980 kz1000 ltd with a vintage regulator and its not wrking its all damaged and i was wanting to put a newer regulator on and do away with the old wat i am asking how hard will it be or is it just a plug and go
regulator prob 26 Sep 2015 14:01 #692043
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
Easy, yes.
Use the search feature here. Tons of info.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
regulator prob 26 Sep 2015 14:14 #692047
  • Thank you received: 2829
regulator prob 26 Sep 2015 17:41 #692075
  • goldylox
Anything pacific should o search first time on site...
regulator prob 26 Sep 2015 20:20 #692091
  • missionkz
Up at the top where it says FORUM.... put your cursor over it and a sub menu will drop down.
Now look for the SEARCH icon and click on it...
Then just look for the "KEYWORD" box and type in what you are looking to learn about.
Bruce
1977 KZ1000A1
The following user(s) said Thank You: goldylox
regulator prob 27 Sep 2015 03:30 #692101
  • goldylox
Anouther question when i have jumper cables on bike it runs good but when i take them off the bike slowly dies but my battery is brand new
regulator prob 27 Sep 2015 04:53 #692113
I hope you are not connecting the jumper cables between your motorcycle and a vehicle that is running or a battery charger. Doing that can clobber your motorcycle's electrical system. :( Ed
Last edit: by 650ed.
regulator prob 27 Sep 2015 05:33 #692120
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 519
Yes. Update. easy under a $100 fix. Last street motorcycle I drove, I found a cheap Yamaha, newer one on ebay for $9.99. KZ1075 was running a Dyna S and it had a bright halogen headlight.
And post some pics of that pro-Street. Nice big tire on the back.
regulator prob 27 Sep 2015 12:10 #692165
  • goldylox
Yeah i do have a halo and yes i was jumping it should i just chargr batery and its a kick start so i tought the bike is suposed to start with the kick
regulator prob 27 Sep 2015 15:21 #692200
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2634
You need a modern Reg/Rect. Easy to hook up if you're not afraid of wires.
regulator prob 27 Sep 2015 15:33 #692203
  • JimB
  • JimB's Avatar
  • Thank you received: 9
I replaced my regulator and rectifier with this reg/rec unit. It was easy to install. My charging system
Attachment z1regrecunit-2.png not found
has been working fine since.
You can get one form Rick's electronics also via ebay.
Jim
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
regulator prob 27 Sep 2015 17:52 #692228
  • goldylox
Yeah i ordered one exactly like that can u send me a pic with it wited in on the bike if not i should be able to manage it it co.es in thursday never worked on a motorcycle before but i think i can manage it
