10 amp Ignition fuse keeps blowing 24 May 2015 15:18 #673529
  • RFE81LTD1K
  • RFE81LTD1K's Avatar Topic Author
  • Thank you received: 2
swest wrote: When you're in the high RPM range, the main jet circuit is kicking in. Low float bowl level or clogged pilot jets. Use a guitar string or a strand from a wire brush to clear them.
I have the carbs off with the floats, needles and jest out of it. Including the jets under the little plugs. All look good. Ran wire through all of them anyway and blew through um with carb cleaner and air. Did the same to the carbs.
So what are the floats supposed to be set at and from where do you measure them? To the naked eye they look fine. Their all level with each other and on a parallel line "=" to the carb body itself. (hope that makes since) Other than setting the floats it's time to put um back together and see if anything changed. Also installing a bigger in line fuel filter for better flow.
Thanks guys. I appreciate all the helpful suggestions. Now lets see if any of um cured my problem.
I'll be bock. lol.
81 KZ1000 LTD
All original.
15k miles.
The topic has been locked.
10 amp Ignition fuse keeps blowing 24 May 2015 17:04 #673551
  • Randombeat
  • Randombeat's Avatar
  • 0 to 100 real quick...
  • Thank you received: 23
Theresmanfewn",hidden passages" in these carbs, do a quick search for carb cleaning and try to find a post where Patton has included pics of how to get the passages clean, make sure you follow those steps. Search "clear tube method" for setting float heights...
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
10 amp Ignition fuse keeps blowing 25 May 2015 04:32 #673600
  • RFE81LTD1K
Stayed up working on it all night. Setting the floats using the clear tube method was relatively easy other than that I lost count on how many times I had to do it before I got um all as close as I could. Don't ask me what the measurement are. I just used my calipers and eyeballed what I thought was about 3mm and set um all as close as I could to that. They were waaaaay off. The adjustment tabs didn't look like they had ever been set. They were all straight/level with the float frame. Now their bent down a good 1/16" of an inch.
Anyway ... I don't want to get too excited just yet but I think my problem might be fixed. Only rode it for about 20 minutes but so far so good. I'll need a little more seat time before I'm convinced it fixed.
Gotta get some sleep now. I'll fill yall in later after I've had a chance to ride it a little more. (if it doesn't rain today)
Thanks for all your help.
Robert
81 KZ1000 LTD
All original.
15k miles.
10 amp Ignition fuse keeps blowing 25 May 2015 05:42 #673602
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
That's too much. The tangs should only be slightly bent otherwise the needles will be cocked to one side and leak. If they do, bend the float arms and have the tang level. It doesn't take much because of the lever effect. Be careful doing this. Pics, pics pics, always pics.
10 amp Ignition fuse keeps blowing 29 May 2015 13:26 #674399
  • RFE81LTD1K
I understand what your saying about the tangs possible pushing the needles off center causing them to leak. But wouldn't bending the float arms defeat my adjustments and put me right back where I started? Never mind ... I get it. But with my luck I'll break the floats off the arms. :(
Unless their leaking internally, their not overflowing externally. Although ... it is really cold natured. Or possibly so I think. Cold starts it obviously takes a few minutes to warm up. But after it's warm and then sits for 15-20 minutes (still somewhat warm) I have to choke it as if cold to get it started and warm it up again.
Please don't tell me I need to tear everything back apart and wrestle those carbs out AGAIN. :angry: Having the stock air box in the way you know what I have to do to get um out. It's a royal pain in the a$$. Lets just say if I keep having to take um out ... pod filters are looking better all the time.
Speaking of pod filters ... Thing is I like the chromies on the sides of the air box and it filling in the otherwise empty hole where it is. With that in mind and knowing the use of pod filters is a far cry better than the stock air box, I got another box from a fellow member with the intention of modifying the front of it making room for pods to at least partially stick inside of it. I don't really like the sucking sound you hear from the carbs with pods on um so I may even make some extensions putting as much of the pods inside of it as possible. Yes, I know that may defeat some of their performance but not the ease of being able to pull the carbs in which is my objective anyway. Worst case I end up with the same performance as a stock air box.
But who knows? I may not do any of that and hope if I have to pull the carbs again it'll be the last time ... for a while. :unsure:
81 KZ1000 LTD
All original.
15k miles.
10 amp Ignition fuse keeps blowing 29 May 2015 13:58 #674407
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
Look at the geometry of the tang as the float creates an arc from no fuel to full fuel....vs the tip of the needle (not the point in the seat).
With the tang bent too far it wipes the tip instead of the arc pushing it "straight" into the seat.
I am not sure how far is too far though.... ?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
10 amp Ignition fuse keeps blowing 29 May 2015 18:02 #674457
  • SWest
  • SWest's Avatar
  • 10 22 2014
I replace my float bowl screws with Allens. I can take the offending bowl off any time I want. Out here in the desert you got bugs, sand and god knows what else. Yeah, I found a gnat in one, once. :huh:
10 amp Ignition fuse keeps blowing 30 May 2015 00:56 #674486
  • RFE81LTD1K
If I have in fact bent the tangs too far down and now their pushing the needles at an angle, the spring loaded pin in the top of the needles must be compensating for some of that angle allowing the needles to seat. As far as I can tell they are not leaking. (knock on wood) Lol.
So far this thread has gone from me blowing fuses leading to various possible electrical problems and now to carb floats. Getting back to where we started, so far I have not blown any more fuses. I never found exactly what the problem was. All I did was re-wrap parts a few wire harnesses and clean a few harness plugs. I flipped a coin on which one fixed it and the harness wrapping won. Lol.
The poor running at low rpm issue was apparently solved after making sure the carbs were clean and or by setting the floats. Again it's a coin toss.
Still don't know why it acts so cold natured. My guess is there's still something wrong with the carbs. Like maybe the floats are now too low making it starve for fuel until choked. But if that was the issue, how/why would it run/idle fine once warmed up again? Otherwise it runs really good.
81 KZ1000 LTD
All original.
15k miles.
10 amp Ignition fuse keeps blowing 30 May 2015 05:47 #674493
  • SWest
  • SWest's Avatar
  • 10 22 2014
Having the needle cocked to one side can wear out the seat bore.
The fuse issue could have been resistance caused by bad connections.
What kind of carbs do you have? The cold blooded issue could be the fact they ran them lean to satisfy the Lib's or diaphragms.
10 amp Ignition fuse keeps blowing 30 May 2015 10:57 #674522
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 633
RFE81LTD1K wrote: If I have in fact bent the tangs too far down and now their pushing the needles at an angle, the spring loaded pin in the top of the needles must be compensating for some of that angle allowing the needles to seat. As far as I can tell they are not leaking. (knock on wood) Lol.
Had that same fuse problem this past week, and solved it by redoing the stator wire connections, of which one (of the three) had come loose...found behind the tranny cover, behind the starter.
1982 KZ1100-A2
10 amp Ignition fuse keeps blowing 01 Jun 2015 18:49 #674874
  • RFE81LTD1K
Wow. Thanks. I would have never thought to look there. I'll remember that for future reference.
81 KZ1000 LTD
All original.
15k miles.
10 amp Ignition fuse keeps blowing 01 Jun 2015 18:56 #674876
  • RFE81LTD1K
swest wrote: Having the needle cocked to one side can wear out the seat bore.
The carbs are Mikuni.
81 KZ1000 LTD
All original.
15k miles.
