Forum
  • Register
  • Page:
  • 1
TOPIC: Dyna Coil Installation KZ1000 Ltd
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #289352
  • Tommotbird
  • Tommotbird's Avatar Topic Author
  • Member
  • Member
  • Thank you received: 0
Hi, I am just installing green 3ohm Dyna coils to my KZ1000 and I am not sure which plug leads attach to each coil. Is it 2 & 4 that attach to the left coil and 1 & 3 that attach to the right coil (facing forward on the bike). Also does it matter which whether these leads connect to the front or rear towers on the coils.
Many Thanks
Tommotbird
Triumph Thunderbird Sport
Triumph Legend
Lambretta SX150
Moto Guzzi V11 Sport
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #289367
  • OnkelB
  • OnkelB's Avatar
  • Thank you received: 75
1/4 attach to one coil, 2/3 to the other and no, doesn't matter which tower you connect to.
As for left/right coil you can't really be sure on an old bike that might have been modified along the way - what matters is how the coils are connected at the timing plate.
Remove your ignition cover and look at the timing plate - the left set of points (or pickup if you have electronic ignition) trigger the 1/4 coil, the right set of points/pickup trigger the 2/3 coil - one will have a black wire, the other a green.
Connect the black and the green wire to the coils so the wire from the left set of points/pickup connects to the coil that has the 1/4 plug wires and the wire from the right set of points/pickup connects to the coil that has the 2/3 plug wires.
77 KZ 650 B1, 82 GPz 1100 B2.
Last Edit: by OnkelB.
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #289384
  • Tommotbird
  • Member
  • Member
Thanks onkeIB
That explains why two longer NGK plug caps were attached to one old coil & two short ones to the other.
Tommotbird
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #289386
  • otakar
  • otakar's Avatar
  • Member
  • Member
  • Thank you received: 25
What year LTD? Is it with stock Kawasaki electronic ignition.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #289389
  • Tommotbird
  • Member
  • Member
Hi Otakar
It is a 1982 K model and I believe it has stock ignition
Tommotbird
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #289427
  • otakar
  • otakar's Avatar
  • Member
  • Member
Than The 3 Ohm coils will not work. You require 2.2 Ohm Coils otherwise you will blow your ignition module. I almost made the same mistake on my Scratch built GPZ1100. Fortunately I caught it in time.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last Edit: by otakar.
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #289431
  • Buda
  • Buda's Avatar
  • Member
  • Member
Ive been runnin the 3 ohm coils of a year now with no problems. Where did you get that info otakar? I dont want to cause myself any extra trouble but buying another set of coils is a little pricy.
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #289436
  • otakar
  • otakar's Avatar
  • Member
  • Member
Kawasaki used 2.2 Ohm systems from the first electronic ignition systems threw about 1990 when they switched back to 3 ohm. You will eventually burn out your module or your coils. Your system will run very hot. If you check your Kawasaki manual it will tell you that the coils must test between 1.8 & 2.8 Ohms. If they test at the low side the spark will be weaker, If they test at the high side the spark will be stronger and the system will run hot. The only exception to this is the 1300 which did run a 3Ohm system.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #289483
  • Moderator
  • Moderator
  • Thank you received: 1229
thomas ed wrote:
Ive been runnin the 3 ohm coils of a year now with no problems....
Okay where also using Dyna-S ignition and by-passing or discarding the igniter.
The oem ignition, igniter and lower ohm coils work together. The Dyna-S ignition replaces the oem ignition and igniter, and works with the green Dyna 3ohm coils.
Good Luck! :)
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #289671
  • Buda
  • Buda's Avatar
  • Member
  • Member
Looks like Im gona be buyin the dyna s
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #289706
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 610
Why is this? I've used three-ohm coils for years with the stock ignition.
Obviously, 3-ohm coils will use less current than 2.2-ohm coils since they have higher resistance. This means the ignition will run cooler, not hotter. BTW, Every stock Kaw electronic ignition coil I've measured was from about 2.4 to 2.7 ohms, but they are old.
Are you saying the primary side's induced voltage (in the 400v to 600v range) will be higher in the 3-ohm coil and possibly damage the output Darlington? But the protection Zener should bleed off the excess until the spark can initiate. Then the primary side is only around 50v... well within the Darlington's safety limit.
I'm not necessarily disputing what you're saying, but just wondering the reasoning.
Last Edit: by loudhvx.
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #289739
  • Tommotbird
  • Member
  • Member
Hi Thanks for all your input.
I am now completey confused as to whether the green 3ohm coils will be Ok or not.
I looked on Ebay and have even seen 1.5ohm used red coils advertised as being suitable for KZ dragbike etc. Would you need a ballast resistor in the supply voltage to the coils.
What would be the effect of using a balance resistor with the green 3ohm coils. I am reading that it increase the batery voltage for starting the engine and then it decrease the voltage when the engine is running.
Advice on using the green ones please, Yes or no.
Regards
Tommotbird
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #289740
  • Tommotbird
  • Member
  • Member
Hi looks like I am duplicating some of the discussions on Apollo63740's thread about Ignition Coil Compatibility, my apologies for that I will study that thread.
Regards
Tommotbird
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #289743
  • otakar
  • otakar's Avatar
  • Member
  • Member
I do stand corrected. I have read threw everything that has been written on this thread so far, just to review. And I spoke too soon. By using a coil of to HIGH of resistance the output voltage from the secondary winding will be lowered. It may go down as low as 20,000V from the advertised 30,000V. This is a significantly weaker spark from the manufacturers intentions, and may result in spark "blowout". If the 1.5 Ohm coil is used, a Ballast resistor will have to be installed to raise the primary winding resistance to prevent system burn out. I do apologize for causing some confusion. Just tired I guess. :blush: :blink:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #289749
  • Old Man Rock
  • Old Man Rock's Avatar
  • Member
  • Member
  • Thank you received: 217
balance resistor with the green 3ohm coils or other sized resistive coils
Oh KZ god why..... :blink:
After all this is your spark power we're speak of, why throw other possibilities of failure or non ideal operations into the equation....
Z1 has both the coils (GREEN 3 ohm) and the Dyna-S ignition plates... ~ $120 each. These are basically designed as a match set for your bike.
Install, align, check your ignition timing, done with it!
For the most part, never have to worry about it again. ;)
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
Keihin, 29mm CR specials
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last Edit: by Old Man Rock.
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #289852
  • loudhvx
  • loudhvx's Avatar
Regards
Tommotbird
The green 3.0 ohm coils should be ok for your bike. They will use less current and I think Otakar is saying they'll be safe, but possibly have weaker output than the stock coils. I use Accel 3.0 ohm coils, which if I recall, are electrically very similar to the Dyna 3.0 ohm coils.
Your stock ignition is functionally the same as the stock ignition on my bikes, and the 3.0 ohm coils work great for me. Also, the 3.0 ohm coils will give you the option to go to a Dyna S if you want to in the future. However, the Dyna S produces more spark energy at very high RPMs, but wastes a lot of power at the lower RPMs. This is because of it's fixed, super-long dwell. Your Kaw ignition varies the dwell slightly so is far more efficient, however above 7000 RPM or so, the dwell is still only about 1/3 that of the Dyna S. Luckily, the 3.0 ohm coils seem to have no problem with that, at least in my experience.
Also, on the subject of reliability, if the 3.0 ohm coils somehow damage your stock Kaw igniter, you can fab one for very cheap. Here is a link on how to do that:
www.geocities.com/loudgpz/GPZgmHEImod.html
Geocities will shut down this year, so I don't know how long the link will be good.
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #289898
  • Tommotbird
  • Member
  • Member
Thanks loudhvx
I will go with the greens for now.
Got a spare set of greens that I will sell on Ebay uk. As I have seen a pair of grey 2.2's for sale. Could maybe break even on the deal- I have a couple of spare igniters knocking around too, amazing what you collect over the years "just in case".
Tommotbird
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #290532
  • otakar
  • otakar's Avatar
  • Member
  • Member
Regards
Tommotbird
Hay LOUDHVX
Thanx a lot for that link. That is fantastic. since I have a KZ1300 also, and ignition modules for those are about $200+++ USED I can very easily build one with these. This is really great. I have already saved the Schematic to my computer. This would mean that I can build a new module for less than $75 with everything, for the 1300. Thanx again.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Dyna Coil Installation KZ1000 Ltd 7 years 10 months ago #290629
  • loudhvx
  • loudhvx's Avatar
I'm glad if you can use it Otakar. Luckily, you have the 79 and 80. The 81, as I found out through emails with a 1300 owner, unfortunately uses electronic advance. The module for that bike is really hard to get, at least at a reasonable price.
I haven't tried it, but the HEI mod should work on the 79 and 80 1300-6.
I'm sure you can figure it out, but if you need a diagram for a 6 application, let me know.
  • Page:
  • 1
