Tommotbird wrote:
Hi Thanks for all your input.
I am now completey confused as to whether the green 3ohm coils will be Ok or not.
I looked on Ebay and have even seen 1.5ohm used red coils advertised as being suitable for KZ dragbike etc. Would you need a ballast resistor in the supply voltage to the coils.
What would be the effect of using a balance resistor with the green 3ohm coils. I am reading that it increase the batery voltage for starting the engine and then it decrease the voltage when the engine is running.
Advice on using the green ones please, Yes or no.
Regards
Tommotbird
The green 3.0 ohm coils should be ok for your bike. They will use less current and I think Otakar is saying they'll be safe, but possibly have weaker output than the stock coils. I use Accel 3.0 ohm coils, which if I recall, are electrically very similar to the Dyna 3.0 ohm coils.
Your stock ignition is functionally the same as the stock ignition on my bikes, and the 3.0 ohm coils work great for me. Also, the 3.0 ohm coils will give you the option to go to a Dyna S if you want to in the future. However, the Dyna S produces more spark energy at very high RPMs, but wastes a lot of power at the lower RPMs. This is because of it's fixed, super-long dwell. Your Kaw ignition varies the dwell slightly so is far more efficient, however above 7000 RPM or so, the dwell is still only about 1/3 that of the Dyna S. Luckily, the 3.0 ohm coils seem to have no problem with that, at least in my experience.
Also, on the subject of reliability, if the 3.0 ohm coils somehow damage your stock Kaw igniter, you can fab one for very cheap. Here is a link on how to do that:
www.geocities.com/loudgpz/GPZgmHEImod.html
Geocities will shut down this year, so I don't know how long the link will be good.
