  • Page:
  • 1
engine idol revs high 22 Oct 2016 13:46 #745943
  • jackstack101
  • jackstack101's Avatar Topic Author
  • Thank you received: 0
Hi my name Jackstack101 i'm new to this forum, i have a 1981 kz 750 ltd with the keihin cv34 carb.
i'm having issues with the idol. it's not my cable and it's not a leak in the boots. when i push down on the one of 3 small screws on the linkage between the carb 2 of them move in unison and one independently i can get the idol back to its proper setting however if i touch the throttle at all then the issue will resume . the screws can be adjusted and i'm assuming that's what needs to happen but i'm not sure how much of and adjustment to make, does anyone have experience with this?
engine idol revs high 22 Oct 2016 14:31 #745947
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2678
Did you vacuum sync the carbs? Replace the rubber boots on the cylinder head? Airbox attached in backof the carbs w/air filter installed? Are the carbs clean and the pilot screws adjusted to 2.5 turns open from lightly seated?
engine idol revs high 22 Oct 2016 15:09 #745949
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
I'd check the spark advance to be sure it's not sticking.
engine idol revs high 22 Oct 2016 17:09 #745960
  • jackstack101
I have not touched the sync screws yet. I had just rtv'ed the intake boots(for a temporary fix) and tested them while running with wd40 and did not get a change in idle. The airbox is installed with stock filter. The carbs were cleaned recently and installed new oe main jets because they didnt all have the same jet size. Idle mix screws still have factory caps on them. -when it does rev up its going around 4 to 5000rpms
also thank you very much for the prompt response
Last edit: by jackstack101.
engine idol revs high 22 Oct 2016 18:08 #745967
  • SWest
  • SWest's Avatar
  • 10 22 2014
You need to take the caps off and adjust the screws.
engine idol revs high 22 Oct 2016 18:38 #745973
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
If the caps are the pressed in aluminum caps, then I'd bet real money that the carbs were not disassembled and properly cleaned.
Those carbs are not terribly complicated, but you have to have a carb synchronizing tool and a genuine Kawasaki factory service manual is indispensable. Once the carbs are spotlessly clean, then the various adjustments need to be performed in the proper sequence or you will end up chasing your tail.
One of the best synchronizers is the Morgan Carbtune.
You may be able to find a copy of the service manual here - www.zedrider.co.uk/service--owners-manuals.html
engine idol revs high 22 Oct 2016 19:19 #745981
  • Nessism
  • Nessism's Avatar
  • Away
TexasKZ wrote: If the caps are the pressed in aluminum caps, then I'd bet real money that the carbs were not disassembled and properly cleaned.
Yes, this. Spotlessly clean. And replace the boots with new. Spraying crap on the boots is a poor indication of possible vacuum leaks. And a poor idle can often be traced to poor vacuum sync.
engine idol revs high 23 Oct 2016 08:03 #746009
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 600
swest wrote: I'd check the spark advance to be sure it's not sticking.
And good boots.
Valve lash and ignition timing all must be right before one goes chasing carb adjustments.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Last edit: by slmjim+Z1BEBE.
engine idol revs high 23 Oct 2016 14:21 #746033
  • jackstack101
thank you and everyone else for the input ill keep you posted the next time i get to her
  • Page:
  • 1
