richard wrote: I get putting pods on CV carbs to look cool
But here it is,when you open the throttle with the bike off
The slide does not move..the slide only moves when the correct amount of air passes through
The carbs uper intakes,hense the name constant VELOCITY,this is achieved by an air box,filter
And small cut away in the box ,the engineers at Kawasaki didn't use a dart board do come up with
The dimensions to make it all work , a lot of science here
Anyone who says they can set up CVs has no idea how good the stock set up WAS
To illustrate how CV carbs work see:
Notice at time 1:20 when the throttle is opened the throttle vacuum passage opens and the throttle vacuum passage retracts. This causes the throttle slide and jet needle to rise. The amount of air that is drawn through the main intake is critical in that the more air drawn through it the less vacuum is available at the throttle vacuum passage which in turn affects the movement of the throttle vacuum passage. At time 1:56 with the throttle wide open the vacuum at the vacuum passage pulls the diaphragm and jet needle all the way up.
As I see it the difficulty in getting pods to work well on the CV carbs is dealing with the fact that the resistance to air flow through the main intake is reduced which in turn reduces the vacuum available to pull the diaphragm up. Consequently, tuning the carbs so the engine runs great at wide open throttle will normally be detrimental to the way the engine runs at other throttle openings and vise versa. This may not be of any importance to a person using the bike on the track since he will not necessarily care about how the engine performs at moderate throttle openings, but for street use this can be an issue. See
kzrider.com/forum/3-carburetor/585949-po...-a-free-lunch#585949 for extensive testing and dyno info.
Also here's an article quoting a Mikuni engineer who helped design motorcycle airboxes. Ed
Attachment poddoc-2-3-4-5.jpg not found
