gixxerkidd03 wrote: i will get are around to the clear tube test soon. i've done it once before, id like to know what size jets are commonly run with an 4-1 exhaust and pods, i dunno if its running to lean/rich?
any ideas on what would cause a small back fire in a carb?
with out vacuum i have to run in PRIM right? im thinking as long as the floats are right there should be no problem.
Main jet size governs mixture at WOT.
Negligible influence on mixture at less than WOT.
Would use size that produces best spark plug reading via throttle chop test.
A 1 or 2 size larger than stock main jet is often used with 4>1 and pods.
Jet needle clip position governs mixture throughout mid-throttle range.
The stock clip position may be okay with 4>1 and pods.
Could experiment with richer clip position.
Pilot jet size governs mixture at idle and low throttle range.
Tuning and testing should be done only with perfectly clean "as new" pilot circuits.
If have steady idle and strong pull-away, size is likely okay.
Might test run with 1 or 2 size larger than stock pilot jet with 4>1 and pods.
Backfire through carb may result from too tight intake valve (insufficient clearance), where combustion partially escapes through the imperfectly seated valve.
With perfectly functioning float valves and floats, and fuel level within specs, and no fuel leakage from any other source, running with petcock in PRI position should be okay. Would take necessary steps to stop fuel flow into carbs whenever the engine isn't running, such as when the bike is parked.
If not already done, would install a good aftermarket in-line fuel filter.
