  • Page:
  • 1
still not right 27 Feb 2015 12:55 #662898
  • ewolpert
  • ewolpert's Avatar Topic Author
  • Thank you received: 0
So, I am trying to get my carbs dialed in. I have fixed the main jet problems but I still cannot get all 4 carbs running at 20cm Hg, or eve around that. I can loosen one one slide and get 3carbs to run around 15 cm but when I try to dial in the last carb the motor dies. Any reason why this may be? (pilots too small etc...)
Eddie
78 KZ650 b2a
still not right 27 Feb 2015 13:59 #662904
  • Thank you received: 2829
How many rpm is the engine turning while you are trying to sync the carbs? Ed
still not right 27 Feb 2015 18:27 #662938
  • ewolpert
Unfortunately, I dont have a tach hooked up so I cant say. I would have to guess not very high. By the sound of the bike sub 1000.
Eddie
78 KZ650 b2a
still not right 27 Feb 2015 19:08 #662940
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
Too low. You do need a tach to be accurate. Try with the RPM's at around 1200. When you get them even, things will change.
still not right 27 Feb 2015 19:51 #662942
Right. You need a tach so you know where your idle is set. Even if you hook one up temporarily; although I can't imagine why you would not want one mounted for use when riding. If you have a dwell meter it will have a tachometer function that you can use when adjusting the idle speed. If your bike still using contact points in the ignition system you should have a dwell meter anyway in order to accurately set the points. Ed
Last edit: by 650ed.
still not right 27 Feb 2015 21:56 #662948
  • ewolpert
I will pick a dwell meter up tomorrow. Any suggestions as to brand?
Eddie
78 KZ650 b2a
still not right 28 Feb 2015 07:10 #662961
Any reputable brand should be fine. A while back I I bought a really nice one (MAC Tools ET985 - see image below) from eBay for very little money. If you're not in a hurry eBay often has decent deals. Ed
Attachment DwellMeter.jpg not found
still not right 28 Feb 2015 07:26 #662962
  • kaw-a-holic
  • kaw-a-holic's Avatar
  • Thank you received: 248
Harbor Freight sells a multi-meter with an induction pick-up that works just fine for under $30. Yes it's cheap but if you only use it once or twice a year it works just fine.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • Page:
  • 1
