Leaking from multiple overflow tubes
- Merlinsbeard
Also, z1 doesn't seem to have needle valves and seats for my year. Does anyone know if they are compatible with any other year? or where to find them?
thanks
1979 KZ650 B3
- Thank you received: 2829
Do you have the part number for the float valve assembly? If so, please post it, and we may be able to help you find one.
In a different forum you mentioned you had set the fuel level with the bike on the side stand.
I HIGHLY recommend you buy a Kawasaki Service Manual. It contains all the info you need to maintain your bike including how to properly set the fuel level. I don't know who may have told you to set it with the bike on the side stand, but consider this - the fuel height is critical to the engine running not only when idling but also while you are actually riding the motorcycle. So the fuel height must be set when the bike is oriented as when riding. Setting it with the bike on the side stand means the fuel level in the carbs you measure from the left side will be too low when upright, and the carbs you measure from the right side will be too high when upright. Please do yourself a big favor and get the manual. No one has ever regretted buying one. Ed
- bountyhunter
- Thank you received: 337
If not already done: the tank and petcock must be cleaned and all rust removed and then inline filters installed. If there is any dirt or rust in the tank it will just keep flowing downhill and fouling the carbs.
- Merlinsbeard
I didn't word my post correctly. I did set the heights with the carbs dead level. I then set them in a soft vice at the angle that the bike sits at on side stand, just to check for leaks. I was trying to determine whether it was an issue with cracks in the bowls or overflow tubes.
However. Today, i set them level again and left the tank on prime for a while. They still leaked after a while. So. i took all the bowls off, set them upside down on the bench with the floats still attached to put just gravity pressure on the needles, and turned the prime back on. Two of the seats welled up just slightly, and leak even when applying pressure to each. So I think I need some needles and seats.
The only site i can find that even has part diagrams for the 79' is partzilla. They list the sets as 16030-1001 and have them in stock. But are these parts reliable? I have read that sometimes these come from Taiwan and aren't very good quality. Also $136 for 4 of them HOLY SHIT is that right? Would it be cheaper to buy rebuild kits?
1979 KZ650 B3
- Merlinsbeard
Kits like this make me nervous because they're giving me four full kits for $50 and partzilla wants $136 just for the valves and seats.
Any advice or testimonials is much appreciated.
Also, bounty, i'll give that a shot, what have i got to lose!? lol.
1979 KZ650 B3
www.nwvintagecycleparts.com/search-resul...earch.x=8&search.y=9
- ezrider714
- Thank you received: 38
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere)
- ezrider714
Dyna Coils
- PLUMMEN
- Thank you received: 104
- ezrider714
Dyna Coils
- bountyhunter
If they are not surface pitted from rust, you can get them to seal. If they can't be smoothed out, then you have to get new needles.Merlinsbeard wrote:
- Thank you received: 2740
