  • Page:
  • 1
KZ1000-A2 build help 12 Oct 2021 11:58 #856552
  • Kaylinator
  • Kaylinator's Avatar Topic Author
  • Thank you received: 74
Hey folks. As I have mentioned earlier in my build thread, I've started doing a bit of drag racing with my KZ1000. My best time so far was on my first night, running a 13.078 @ 100.75 MPH, which I thought was pretty good first time out, and knowing that cylinder 2 is a bit hurt.
I went out the next week and started having issues. It would seem to launch just fine, but then suddenly bog down to nothing. I'd basically have to close the throttle and crack it again to bring it back to life. So, questions.
1. What might cause the bog off launch? My guess would be that I was launching at too high an RPM, and with such a sticky track, it was grabbing too hard and bogging the motor down?
2. With cylinder 2 hurt, I've got plans to rebuild the motor this winter. I might be able to get away with a hone and rings, but looking at maybe going big bore. Can I reliably run a 1075 Wiseco kit on the stock carbs (VM26)?
3. I'm also thinking about giving it a different cam. I pretty much daily this thing throughout the summer, so I'm not looking to overdo it, just looking for mild performance gains. I don't know a whole lot about cams so I could use an education. From what I can tell, a Webcam 118 grind would be best if I don't bore out the motor, is that correct? What cam should I look at if I do bore the motor?
Thanks for taking the time to educate this noob.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
KZ1000-A2 build help 12 Oct 2021 12:29 #856553
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1883
People with way more experience will chime in but your better bang for money vs performance is in the cams and ported head. Bigger bore without the air flow isn’t the way to go.
KZ1000-A2 build help 12 Oct 2021 14:23 #856565
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 518
No eBay APP ID and/or Cert ID defined in Kunena configurationFor engine mod tips and the best combinations, I would look up similar replies on this site from Larry Cavanaugh.   kzrider.com/forum/profile/25825-larryc
Here is another Cavanaugh reference:https://www.kz-1000.net/post/130285291257/faq-about-kz900-kz1000-engines
If you upgrade to a 1075 kit, most folks go with the 10.25:1 compression as opposed to the stock-ish 9:1.  In this case, I think higher compressor allows for/requires performance cams.  But Larry generally seemed to recommend modest cams along with good porting (his specialty).  He seemed to be a fan of the 118 grind.
kzrider.com/forum/2-engine/253470-there-...am-on-a-kz900#253563
As for sticking with the 26mm carbs, there is no reason they would not work.  However, you might be giving up some power at the top of the RPM range as a smaller carb body can only pass so much air volume.  On the other hand, smaller carbs are said to have better throttle response in the middle range than larger ones.
The place where you might run into trouble with the VM26 is if you went with a really big gnarly cam.  As the cam gets more aggressive, generally the optimal power range moves to a higher RPM.  A gnarly cam paired with small carbs could mean that as the RPMs climb, just when the cams start really working they get choked by the smaller carbs.  So that would be bad.  But it doesn't sound like that's the direction you're going.
A modest upgrade might be to find a set of VM28s from a 79/80 KZ1000.  These have accelerator pumps and are not in really high demand, although prices for all of this stuff have gone up a lot recently.  You might have to watch Ebay for a while before you find a good set at a reasonable price.
This is what they look like, but don't buy these because they are gross and overpriced.
Or send a note to Nessism and see if he has a set.  He's been rebuilding them for fun.  kzrider.com/forum/profile/14026-nessism
My dad's '74 Z1
'00 ZRX1100
The following user(s) said Thank You: Kaylinator
Last edit: by DOHC.
KZ1000-A2 build help 14 Oct 2021 12:03 #856642
  • Southpaw
  • Southpaw's Avatar
Need more info, What rpm are you launching?? Is it bogging off the line? or after you leave?
KZ1000-A2 build help 14 Oct 2021 12:18 #856644
  • Kaylinator
I was launching right around 6500 RPM. It worked out great the first night at that RPM. It was bogging right after I'd leave with 5 - 10 feet. I was trying to find a video of it happening, but it isn't very obvious in video. From the saddle it feels like I may as well put my feet down.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
KZ1000-A2 build help 14 Oct 2021 16:49 #856654
  • Southpaw
  • Southpaw's Avatar
You might wanna check fuel flow. 6500 should be a good launch rpm. Maybe try 6000.
  • Page:
  • 1
