Let's see YOUR drag bike ! 17 Jun 2021 08:11 #850309
  • Bdog
  • Bdog's Avatar
  • Sweep the leg johnny!!!
  • Thank you received: 9
Here are mine.
Working on getting them track ready for this summer.
Interested in knowing a little more about that 650.
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
Let's see YOUR drag bike ! 17 Jun 2021 13:26 #850317
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1973
One of our 2 dragbikes   mid 80s.
Let's see YOUR drag bike ! 23 Jun 2021 18:11 #850681
  • Injected
  • Injected's Avatar
  • Thank you received: 423
The red 650 is my old street bike, it has a 831cc motor and mechanical fuel injection, it runs alcohol. It was built into a drag bike by me and a friend in 1995.
The Z1 is now black and runs a 1327cc motor with 40mm Lectrons. I am just finishing up a complete rebuild on it, it has a scratch built custom chassis, not a back half conversion. I bought it as a roller and built the motor.
I have another lay down car tire frame I am also going to rebuild. It has "Race Design" and "Grand Island Precision" lettering on the rear fender so it may have been worked on by Paul Gast at one point. It had a Denco "Stage 3" motor in it, but I only bought the rolling chassis and have a 1200cc Z1 motor going into it with a Eaton supercharger.
Last edit: by Injected.
Let's see YOUR drag bike ! 24 Jun 2021 05:56 #850693
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 519
Lets see that car tire frame. Race Design was the Infamous "PUPPET" from the early 80's Pre- "Racevisions" Don't ruin that paint! Puppet painted that! As these items also. Pictures!!
Let's see YOUR drag bike ! 24 Jun 2021 07:12 #850696
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1470
Let's see YOUR drag bike ! 24 Jun 2021 09:45 #850705
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1865
Love it. No bragging just plan and simple. Here it is. Take a chance at your own risk. Awesome.
Thats confidence!!!
Let's see YOUR drag bike ! 24 Jun 2021 09:55 #850706
  • Injected
  • Injected's Avatar
This is the car tire frame - FBG/Race Design (some of the pics not so great)
It has a 15" x 8" slick, so small car tire (VW?) So far all I did to it was take all the stickers off the tail and remove the two stroke motor mounts. I mocked up the engine in the frame to make sure it will fit with the supercharger mounted behind the head.
Personally I don't think it is a Puppet frame, its a bit too sloppy/jenky to be his work. I have seen some of his work up close and the frame I have is a beginners work that was possibly done by somebody that had too many beers.
Let's see YOUR drag bike ! 24 Jun 2021 12:50 #850710
  • urankjj
  • urankjj's Avatar
  • Thank you received: 201
I owned this bare frame back in the 80's. This was taken after the annual Fairbanks Alaska drag races, on the way back to Anchorage. Fairbanks would shut down one of their main streets and set up the lights and let the drag racers have at it. Good fun back then.....
Let's see YOUR drag bike ! 24 Jun 2021 13:50 #850711
  • zed1015
  • zed1015's Avatar
Looks to be a Kosman frame same as mine.
Let's see YOUR drag bike ! 24 Jun 2021 14:35 #850713
  • urankjj
  • urankjj's Avatar
Yes it was definitely was a Kosman frame.
Let's see YOUR drag bike ! 24 Jun 2021 17:37 #850717
  • urankjj
  • urankjj's Avatar
Some old footage of Polar Raceway, outside of Anchorage, from back then. The Kosman might be in it..... Polar Raceway 1984 part 1 - YouTube
Let's see YOUR drag bike ! 25 Jun 2021 07:20 #850731
  • Injected
  • Injected's Avatar
So what is your opinion on that roller?
You can see in the last picture the lower frame rails are wonky, up close the welding is terrible, looks MIG welded to me. It looks like there was no attempt to get it symmetrical.
I talked to my local drag race guru and he says he can fix it no problems.
I am just looking to build a nice nostalgia bike I can run on test and tune day, I am not going to bracket race it for points.
