Drag strip trip. 05 Sep 2016 13:06 #741216
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2629
The pics loaded but the clip didn't.
Was sent a link to a new track near me. I don't know if they have a 1/4 mile though. :unsure:
goracecvr.com/
Drag strip trip. 07 Sep 2016 01:20 #741361
  • zukdave
  • zukdave's Avatar Topic Author
  • Thank you received: 229
Worked for me but try this.
I messed with it some more last night it's shifting the 1-2 shift but will make the next shift so I'll call D/D today
and see what they say.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Drag strip trip. 09 Sep 2016 04:39 #741666
  • zukdave
I Found what I was doing wrong in the setup programming it work's now.
In this step I read it as I need to set it for 1,2,3,4 shift's but turns out setting it for
one of those it turned OFF the ign. kill those settings are for if you have a auto shift tranny.
For those that don't know there is a mod. you can do to a lot of bike tranny's that will make it
auto shift but you CAN NOT compression brake while in one of the auto shift gear's.
[/URL
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 09 Sep 2016 09:29 #741691
  • zukdave
Click the pic.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: by zukdave.
Drag strip trip. 09 Sep 2016 11:28 #741712
  • KZB2 650
  • KZB2 650's Avatar
  • Thank you received: 265
I love the smell of rubber and goose bumps up and down my spine in the morning. ;)
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Drag strip trip. 11 Sep 2016 18:09 #741899
  • zukdave
Little update since I got the box working right I've been able to play with the rpm setting's and kill time's
and right now a 9500 rpm 1-2 shift feel's like the Astro van pulling off from a red light doing the 1-2 shift.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 12 Sep 2016 07:56 #741943
  • KZB2 650
  • KZB2 650's Avatar
Why not a shift point at 10,500 or a little higher? My stock 750 cams are red lined at 9,500 but I thought with the GPZ cams its more like 10,500 +.
1978 KZ650 b-2
Drag strip trip. 12 Sep 2016 16:10 #741989
  • zukdave
For one I was on the street and two factory red line is 9800 if I remember right.
I have foot shifted at 11,500 but with stock cams there's no reason to turn it that hard.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 26 Sep 2016 22:53 #743678
  • zukdave
Looks like Revivalcycle's here in Austin that puts on the Handbuilt show is going to have a race at little River
for the vintage/cafe bike's. Think I'll show up with my little 650 and see if I can hurt a few feeling's. :evil: :evil:
revivalcycles.com/blogs/the-twist-off-media
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 25 Oct 2016 15:39 #746200
  • zukdave
Well what started as a simple valve adjustment and compression test turned in to the top end coming off.
Intake's where .004, .005, .004, .004.
Exh. where .003, 003, .003, .007
Did the comp. check and cyl. four was 30 psi lower then the other's so pulled it apart
and found #4 intake valve not seating right so I'll relap all the valve's and see what the seat's look like.
Cylinder's and piston's look like they have never been ran other then some carbon on the domes.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 25 Oct 2016 15:53 #746203
  • SWest
  • SWest's Avatar
  • 10 22 2014
Bummer. :( A little oil getting past the rings?
Drag strip trip. 26 Oct 2016 06:37 #746248
  • bluej58
  • bluej58's Avatar
  • Thank you received: 511
zukdave wrote: Looks like Revivalcycle's here in Austin that puts on the Handbuilt show is going to have a race at little River
Good Luck
78 KZ1000 A2A
