Drag strip trip. 11 Mar 2012 10:16 #509014
  • zukdave
  • zukdave's Avatar Topic Author
  • Thank you received: 229
Time to take the Gpz motor to the drag strip as I haven't
had a chance since they've been closed for the winter.
If your in the centex area come on out and play a little.
The oldest continuously operating drag strip in Texas since about 1949 I think.
littleriverdragway.net/
April first is an all bike day (Sunday)at the track
but their running their normal Friday night deal plus
Saturday then the all bike Sunday so the brew crew's
gonna go Saturday morning and play a little then camp out/party at the track.
Ordering a new rear tire and chain and sprockets tomorrow
then should be good to go.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: by zukdave.
Drag strip trip. 11 Mar 2012 10:20 #509015
  • Old Man Rock
  • Old Man Rock's Avatar
  • Thank you received: 225
Yummy... B) Post your times/speeds after the days events.... :)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Drag strip trip. 18 Mar 2012 10:27 #510394
  • zukdave
OMR I'll be sure to do that along with pic's and video's
Using this calculator
www.skracing.com/horsepower.htm
and based on the factory 87 horsepower I should
get in the 12.30's range.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 19 Mar 2012 22:33 #510744
  • zukdave
New tire, sprocket's and chain and a tach my old ass can see
light up at shift time.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 20 Mar 2012 22:05 #510924
  • LarryC
  • LarryC's Avatar
  • Thank you received: 309
That tach looks good on the bike. Have ball :lol:
Larry C.
Drag strip trip. 03 Apr 2012 01:33 #513723
  • zukdave
Texas party drag's put on by Texas scooter times rock.
I'm tired so story later.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 04 Apr 2012 23:08 #514101
  • zukdave
Ok so we get to the track about 4:00 o'clock Sat.
Get the bike unloaded and camp set up.
Still need to get pic.s from folk's made a pass.
13.61 @85.49 Thinkin it went 13.90 @96 with
the old motor something ain't right.
Next pass 13.67@85.26. so put it up for the night
Got a beer, fired the grill and watched the girls drink beer.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 04 Apr 2012 23:15 #514106
  • zukdave
Sunday morning rode around the pit's to warm it
up and stopped at buddy Beetle's camp.
After that was go make pass's.
Click the pic for video.
Ran these number's on a set of not to good VM-24's.
13.56@94.74
13.39@89.39
13.30@93.34
13.13@96.84
13.07@95.87 with a 1.71 60 ft.
Ran 1.84 1.85 60 ft all day.
My B-day party Sat. night at the drag strip
then Sunday morning makin pass's for breakfast.
PRICELESS...
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 05 Apr 2012 12:31 #514187
  • Injected
  • Injected's Avatar
  • Thank you received: 403
Here is a KZ650 motor timing slip if you would like something to compare with...
Street bike with shocks and no wheelie bar, 831cc motor 10:1, 34mm flat slides, V&H pipe with baffle, rider with gear about 180lbs
Attachment earlytimingslip.jpg not found
Drag strip trip. 05 Apr 2012 21:59 #514267
  • zukdave
Thanks for the time slip.
My motor's a bone stock low milage (8400)
83 Gpz 750 with the little carb's and the pipe.
With carb's and more gear this thing will go a lot faster
it just run's out of breath with the little carb's
but that's all I got right now.
That motor is close to were I'm headed with this one.
Game plan is 810 cc wiseco kit, ported and milled head
thinking send it to Larry C.
Cam's of some grind just not sure on what.
Wired George's 30 mm bored vm 26's.
Sidewinder header.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 08 Apr 2012 23:10 #514777
  • zukdave
My buddy Gerald that I got the gpz
doner bike from hooked me up with a
clean set of 29 smooth bore's.
Broke down and goin to the sonic cleaner at work.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 10 Apr 2012 00:27 #514942
  • Mark Wing
  • Mark Wing's Avatar
My KZ650 with Yoshimura 716cc kit Yoshimura R&T cams 29 smoothbores head work by a VW guy and Yoshimura pipe and struts no bar ran 12.23 all the time and a best of 12.12. I'd usually do 6 or 8 passes between 12.21 and 12.26.
Mark
Yorba Linda Cal.
