Drag strip trip. 09 May 2012 08:35 #520931
  • zukdave
  • zukdave's Avatar Topic Author
  • Thank you received: 229
The arm is off an 83 unitrack.
Best pic I have right now but I'll get one today with a tape on it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Drag strip trip. 09 May 2012 14:14 #521010
  • Mark Wing
  • Mark Wing's Avatar
I'm running the GPZ swing arm like pictured. It' a bit longer too which helps keep the front wheel down. With the stock arm I'd do wheelies all the time and now it's real hard to do wheelies and when I do lift the front wheel it comes down quickly. It's funny years ago when I said my hot 650 went low 12's almost every one told me I was full of s#!t. I never tried a wheelie bar.
Mark
Yorba Linda Cal.
Drag strip trip. 09 May 2012 19:23 #521066
  • wireman
  • wireman's Avatar
  • Thank you received: 299
Mark Wing wrote: I'm running the GPZ swing arm like pictured. It' a bit longer too which helps keep the front wheel down. With the stock arm I'd do wheelies all the time and now it's real hard to do wheelies and when I do lift the front wheel it comes down quickly. It's funny years ago when I said my hot 650 went low 12's almost every one told me I was full of s#!t. I never tried a wheelie bar.
Mark
Its that good california air Mark! :laugh:
Drag strip trip. 09 May 2012 21:27 #521092
  • zukdave
Mark the arms's 2 1/2" longer then stock.
I get the same chit from folk's thinkin I'm talkin trash
when I tell them my junk go's mid to low 12 second's.
F@$&em I got a time slip that told ME that's all that count's!!!!!!!!!!
Back to the arm here's some pic.s
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 10 May 2012 13:15 #521243
  • Mark Wing
Its that good California air Mark! :lol: :lol: :lol:
The 1000's I was spanking were running the same air. ;)
Dave I used the bearing sleeve from a GPZ 550 with my 650 pivot bolt and it all bolted together
Yorba Linda Cal.
Drag strip trip. 10 May 2012 20:53 #521328
  • wireman
  • wireman's Avatar
Its been a while since Ive been to our local 1/8 mile since I sold my 1327,but from what i remember strapped down busas were running 6.70-6.90 range with a little motor tweaking and a pipe around here in the 1/8 around here anyway with decent riders. B)
best I ever got out of the 1327 was a string of 6.15-6.18s /115 and change with no bar and lots of traction issues B)
Last edit: by wireman.
Drag strip trip. 10 May 2012 21:28 #521340
  • zukdave
Mark thank's for that info.
I was going to ream the frame hole
to fit the 750 bolt.
My sleave's are already trimed
to fit the frame but a 550 sleave
would be a better way to go.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 10 May 2012 21:43 #521346
  • zukdave
wireman wrote: a string of 6.15-6.18s /115 and change with no bar and lots of traction issues B)
Best to date 1/8 mile was
7.81/88.08
I'll go set in the corner till
I get some big boy panty's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 10 May 2012 23:53 #521399
  • wireman
  • wireman's Avatar
You can get hurt just as bad at any speed going down the track.
Ive got a 20 year old daughter who could ride my 1327 just as hard as me on the street,ive ridden on the back of that bike with her piloting it on more than 1 occassion before I sold it. :sick:
Only thing Ive got to say is if she ever road that thing with a really sticky tire and a bar I wouldnt want to be in the other lane against my little version of vickie farr! :woohoo:
I really need to get my head out of my ass and build an old gasser out of one of my old 55 chevys or an old 50s chevy truck and stick her behind the wheel and me and the boys can turn the wrenches! B)
Drag strip trip. 11 May 2012 00:16 #521408
  • wireman
  • wireman's Avatar
I wonder how cost affective it would be to set up some sort of progressive nitrous system on a smaller motor like that?
I bet you could use some of those individual nitrous plates/manifolds between head and boots like a 900/1000 since youre already using bigger boots for those 29s.
Then you could adjust it to come on as you get it rolling so it doesnt shock the suspension/chassis so hard B)
Drag strip trip. 11 May 2012 00:42 #521419
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1972
Been along time but we would have 2 and 3 stage systems on our dragsters. One set came on in first gear activated by throttle position. and a second stage in a higher gear set off with a manual button. Its great till you exceed the motors ability to contain the power , then we would have a spectacular blast of fire shoot out the sides of the cylinder head
Drag strip trip. 11 May 2012 01:05 #521433
  • wireman
  • wireman's Avatar
Thats half the fun of racing,fixing/updating once you find the limitations of a design! :laugh:
