Drag strip trip. 10 Dec 2012 12:29 #562317
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
  • Thank you received: 11
I have a circuit somewhere to get that tach working for you.
I had the same one on my KZ1000, worked great. I'll dig it up for you if you are interested.
Build Thread
Drag strip trip. 10 Dec 2012 14:45 #562339
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
  • Visitor
Im running a Autometer on mine without any problems.....just had to get the Dynatek Tach Adapter...it was $21.
www.dynaonline.com/skins/products/access.../Dyna_Tach_Adapters/
Attachment tach_adapters.png not found
The two red eyes goto the coils ( one on each ) The large pinkish plug goes to the input to the tach...just one wire.
Last edit: by 4TheKZ1000.
Drag strip trip. 10 Dec 2012 14:50 #562341
  • tachrev
  • tachrev's Avatar
4TheKZ1000 wrote: Im running a Autometer on mine without any problems.....just had to get the dyna patch cord...it was $20.
I like how you mounted that.
Here is my post with the explanation of how I did it.
Probably works the same or very similarly to the dyna patch cord. I never realized they made one.
Autometer Setup
Build Thread
Last edit: by tachrev. Reason: Forgot link
Drag strip trip. 10 Dec 2012 15:03 #562342
  • 4TheKZ1000
  • Visitor
Autometer Setup
ya, works the same as patch cord you made....
On mounting....I just used 1-piece of flat steel and bent a bracket. Its mounted to the shock bolt. Very sturdy mounting...dosent move...I try to use KISS when making something....Keep It Simple Stupid..... :laugh:
Drag strip trip. 11 Dec 2012 01:00 #562444
  • zukdave
  • zukdave's Avatar Topic Author
  • Thank you received: 229
4TheKZ1000 wrote: Im running a Autometer on mine without any problems.....just had to get the Dynatek Tach Adapter...it was $21.
So will make this tach work for me ?
I called Auto meter and they said it ain't happening.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Drag strip trip. 11 Dec 2012 01:09 #562446
  • lushbaugh
  • lushbaugh's Avatar
  • everybodys a pro......
  • Thank you received: 35
no it will work go to radio shack and get the parts in that link. ive used it on a procycle shift minder on a buell. they sent me one of those patch chords and i made one from taking apart for my ducati.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
Drag strip trip. 11 Dec 2012 01:12 #562447
  • 4TheKZ1000
  • Visitor
I road bike for 4 months just about every day...the tach worked fine every time.
I also called Autometer and they couldnt find a bowling ball in a brown paper bag....bunch of dick heads.
I did have to snip two wires that were looped on back of tack per instructions....brown and orange I think.
Drag strip trip. 11 Dec 2012 01:16 #562449
  • 4TheKZ1000
  • Visitor
Make sure you connect tach adapter wires to neg or non-powered side of coil.
Drag strip trip. 11 Dec 2012 01:27 #562451
  • lushbaugh
i cant believe what they charge for that turd part!!!
Drag strip trip. 11 Dec 2012 01:33 #562452
  • 4TheKZ1000
  • Visitor
lushbaugh wrote: i cant believe what they charge for that turd part!!!
Wait till you see shipping fee.....thats what pissed me off.
Man...that T-Mobile chic is smokin hot.... :P
Drag strip trip. 11 Dec 2012 01:37 #562455
  • 4TheKZ1000
  • Visitor
lushbaugh wrote: no it will work go to radio shack and get the parts in that link. ive used it on a procycle shift minder on a buell. they sent me one of those patch chords and i made one from taking apart for my ducati.
Just rem those resistors and diodes....etc.... have a Polarity to them....they can only go one way....if you install them backwards they wont work.....it shows the Polarity on the plastic package and there should be a line imprinted on the item to show which way they go.....
Drag strip trip. 11 Dec 2012 01:38 #562456
  • lushbaugh
yea no joke. and which commercial... hell it dont matter id eat at all those resturants lol
