  • Page:
  • 1
1973 Z1 Valve cover 12 Oct 2023 10:35 #890392
  • lewisj
  • lewisj's Avatar Topic Author
  • Thank you received: 11
Valve cover off a 1973 Z1 in excellent condition.  Interior X markings have been ground down for high lift cams.
Asking $50 , plus $10 shipping.
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
ZR750S front forks
Delkevic exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
1973 Z1 Valve cover 12 Oct 2023 15:37 #890402
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1992
Looks like your cam lobes were polishing the inside of the valve cover
The cure for that is stacking two gaskets together to add a little more clearance
1973 Z1 Valve cover 12 Oct 2023 18:32 #890410
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2644
That's a common mod for high lift cams.
1973 Z1 Valve cover 13 Oct 2023 20:45 #890457
  • sf4t7
  • sf4t7's Avatar
I agree with Steve.  Back when assembling my hotrod motor, I ground the crosses off just in case. But probably didn't need to with the 1X andrews cams.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
1973 Z1 Valve cover 13 Oct 2023 21:02 #890459
  • SWest
  • SWest's Avatar
  • 10 22 2014
Same cams I have.   VM33's, V/H exhaust, 1075 kit and i RIDE THE PISS OUT OF IT.
1973 Z1 Valve cover 13 Oct 2023 21:10 #890460
  • sf4t7
  • sf4t7's Avatar
Yeah, the original plan was for much higher lift cams, but at the last minute I decided I didn't want to lose any "bottom end grunt" - turned out to be the right move.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
  • Page:
  • 1
