  • Page:
  • 1
  • 2
can anyone I'd this fastener 11 Dec 2014 14:22 #655861
  • dkoz
  • dkoz's Avatar Topic Author
  • Thank you received: 17
now after you tell me what it is. Can you tell me what tool to buy so I can get the windshield off of the fairing.I need to mail order..I've try ed vise grips but I'm only going to do more damage. Thanks
Attachment 20141211_160857-1.jpg not found
z1r windshield
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
Last edit: by dkoz.
can anyone I'd this fastener 11 Dec 2014 14:49 #655863
  • floivanus
  • floivanus's Avatar
  • Thank you received: 116
Thats a T nut it has points that dig into the piece it's in; got a bolt head on the other side?
Past; 78 kz1000, 83 kz550
Andrew
The following user(s) said Thank You: PLUMMEN
can anyone I'd this fastener 11 Dec 2014 16:43 #655872
  • jakedude
  • jakedude's Avatar
  • Thank you received: 30
Every hardware store sells them.
Nothing lasts, nothing is finished, and nothing is perfect.
can anyone I'd this fastener 11 Dec 2014 18:02 #655877
  • Klock74
  • Klock74's Avatar
  • Thank you received: 0
you wont get it out on that side, gotta get that bolt out, then she will pop out. that sucker has teeth, dont spin it
can anyone I'd this fastener 11 Dec 2014 18:45 #655878
  • Thank you received: 2098
Good Fortune! :)
The following user(s) said Thank You: !Seymore
can anyone I'd this fastener 11 Dec 2014 18:55 #655880
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
Good job people.
can anyone I'd this fastener 12 Dec 2014 14:25 #655909
  • dkoz
Thanks guy's it has a nylon washer on the other side with a flat head screw. I couldn't hold this tnut with anything that I have so I'll have to search the web to see if there's a tool to hold it.
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
can anyone I'd this fastener 12 Dec 2014 14:31 #655913
  • moneypit
  • moneypit's Avatar
  • Thank you received: 35
Just unscrew the screw. The nut will stay put. Check Pattons pic!
2-76 kz900
St Paul MN
can anyone I'd this fastener 12 Dec 2014 15:54 #655921
  • bluej58
  • bluej58's Avatar
  • Thank you received: 511
If it is spinning put a drop of penetrating oil on the threads and let it sit for a while then try to hold it with a needle nose while someone else unscrews of the other side, there is no special tool for that.
If that doesn't work maybe some glue or epoxy might help to hold it.
Good luck
JD
78 KZ1000 A2A
can anyone I'd this fastener 12 Dec 2014 19:38 #655944
  • SWest
  • SWest's Avatar
  • 10 22 2014
You might try to drill it out from the back side. I've done that with fly wheels. Drilling from the front tightens it but from the back, it spins right out.
can anyone I'd this fastener 13 Dec 2014 02:48 #655948
dkoz wrote: Thanks guy's it has a nylon washer on the other side with a flat head screw. I couldn't hold this tnut with anything that I have so I'll have to search the web to see if there's a tool to hold it.
To help hold the t-nut in position to keep it from spinning while attempting to turn out the flat head screw, perhaps could drill two holes in the areas shown below whereby the t-nut may be grasped with circlip/snap-ring pliars or tips of needle nose pliers. Or could insert metal screws and use a straight edge or nail or whatever between the metal screw heads to hold the t-nut steady while attempting to turn out the stuck flat head screw.
Good Fortune! :)
The following user(s) said Thank You: dkoz
Last edit: by Patton.
can anyone I'd this fastener 13 Dec 2014 07:31 #655951
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1972
Check with some snowmobilers
. These t nuts are used to hold the studs on the tracks and they may have a tool with 3 prongs to hold it still.
I used to take a pair of needle nose pliers and hold the nuts still by just putting the tips in 2 of the 3 notches and holding on tight
Hope this helps
  • Page:
  • 1
  • 2
