  • Page:
  • 1
"J" Pistons 17 Mar 2024 02:13 #896505
  • Wookie58
  • Wookie58's Avatar Topic Author
  • Moderator
  • Thank you received: 1963
Hi guys, bit of a long shot I know but does anybody have a set of 74 or 75mm "J" model pistons with 17mm wrist pins that are usable and sensible money ??
"J" Pistons 17 Mar 2024 02:23 #896506
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 689
Hi Guy, I think I can help you out there.
I swopped the top end of my 1000j to Gpz1100. Flogged the 1000 barrels but sure I've still got the stock pistons in the parts bins some place. I think the 1000j bore is 69.4 though? Def 17mm pins although mine appear to be 72mm with 17's.
I'll go digging and mail you some pics when I find them. Might even have decent rings on them.
Z1000J2 somewhat modified!
Last edit: by Warren3200gt.
"J" Pistons 17 Mar 2024 03:09 #896507
  • Wookie58
  • Moderator
Thanks Warren, stock 1100 is 72.5mm but the 1100uni block I have has one rusty bore so I need either 74mm (1135) or 75mm (1170)
"J" Pistons 17 Mar 2024 08:32 #896513
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 636
MTC1135G-3 fit 74mm bore, and have 17mm wrist pins.
...currently hibernating beneath this cylinder head:
1982 KZ1100-A2
Last edit: by daveo.
"J" Pistons 17 Mar 2024 08:36 #896514
  • Wookie58
  • Moderator
I say, "those are nice"
"J" Pistons 17 Mar 2024 08:57 #896516
  • daveo
  • daveo's Avatar
  • Premium Member
Moving along:
March 20, 2022
Momentarily parked:
photos.app.goo.gl/cQLzcPN9CEzBvm178
My current plan is to repurpose the carbs, Dyna 2000, chrome (and cam) covers, UNI cams(?), cyl head(?), generator components, clutch pack, and exhaust system...to the ZN motor going in.
1982 KZ1100-A2
"J" Pistons 17 Mar 2024 13:01 #896527
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2658
Sounds good.
"J" Pistons 19 Mar 2024 10:17 #896622
  • Wookie58
  • Moderator
So today is one of those "good days to be on this planet" when I reached out on Sunday it was "a bit of a punt" so I was pleasantly surprised when Warren came back to me 10 mins later (followed with an email) with an offer of assistance. Now I was confused as a "J" is 69.4mm and the 1100's are 72.5mm but the pistons offered by Warren where 72mm   anyway when I looked at the pictures Warren sent I got a bit of a tingle in my "tingely place" so a deal was done and the pistons turned up this morning (thanks Warren). Having cleaned one up I am 99.9% sure that my suspicions were correct and what I have received is a Wiseco 1075 kit   so the 1100 uni block can go back to sleep and I will run with these gems in my 1000 block.
PS: Warren I said that if my suspicions were correct I would forward additional funds which I have done (I have factored in for new rings and clips) thank you so much, they have gone to a good home
The following user(s) said Thank You: Warren3200gt
"J" Pistons 19 Mar 2024 10:28 #896626
  • Warren3200gt
Your welcome Guy, like I said they were of no use to me so glad you could put them to good use.
"J" Pistons 19 Mar 2024 10:28 #896627
  • SWest
  • SWest's Avatar
  • 10 22 2014
If I'm not mistaken those are the old style pistons (discontinued). I had the K1015's and they ran great until I lunched one.   I think the new style rings will fit the old style. I'll check later.
  • Page:
  • 1
