  • Page:
  • 1
  • 2
clutch 21 Dec 2023 05:18 #892977
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 656
When "right side" is mentioned, we're assuming it's approx.at the 3 o'clock position in OP's pic of the clutch assy.  If the motor is spun to rotate the "right side" (currently at 3 o'clock in the pic) to 9 o'clock, the bind should then be at 9 o'clock if we understand, providing the defect is in the hub or basket.
This is a long shot - If the bind remains at 3 o'clock after rotating the clutch assy. 180 deg., the answer may be that the final drive chain is torquing the output shaft sideways due to a defective needle bearing, output shaft bearing(s) or both?
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Last edit: by slmjim+Z1BEBE.
clutch 21 Dec 2023 05:33 #892978
  • slmjim+Z1BEBE
If you have a clutch release the has the plastic ramp this  Clutch Release  is a cheap upgrade.
Is that the one that has a half dozen or so ball bearings in a sleeve? Are all KZ650 release mech's of the same design?
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
clutch 21 Dec 2023 06:01 #892979
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 264
The "later" clutch release started in 1978 on the Z1R and KZ650. 1979 and up KZ650, KZ750, and KZ1000 used the updated design.  (according to part number cross reference on partzilla).
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
The following user(s) said Thank You: SWest, Mikaw
clutch 21 Dec 2023 07:52 #892983
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1883
Good Ridin'
slmjim & Z1BEBE
Yes, it has the steel inner “cage” with the steel bearings.
The following user(s) said Thank You: slmjim+Z1BEBE
clutch 21 Dec 2023 08:39 #892984
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 384
I agree that current on line parts lists tend to show the latest part number, but I have some old parts lists that indicate the same (older part numbers) were use on the B1, B2 and B3.
The F1 list I have shows the same parts for it (1980) This list for the F2, F3 and F4 indicate that at some point in 1981 the change to the newer part happened.
jarlef.no/Kawasaki/PDF/Z650/Files/KZ650B1toB3.pdf
jarlef.no/Kawasaki/PDF/Z650/Files/KZ650F1_Parts_List.pdf
z650.surr.fr/parts.html
I can also say there was a change in the push rod diam in what appears to be late 79 early 80 see below
B1 13116-035  7 x 270
 KZ650-B1 (1977)
 KZ650-B2 (1978)
 KZ650-B2A (1978)
 KZ650-B3 (1979)
 KZ650-C1 (Custom) (1977)
 KZ650-C2 (Custom) (1978)
 KZ650-C3 (Custom) (1979)
 KZ650-D1 (SR) (1978)
 KZ650-D1A (SR) (1978)
 KZ650-D2 (SR) (1979)
 KZ650-F1 (1980)
 KZ750-B1 (1976)
 KZ750-B2 (1977)
 KZ750-B3 (1978)
 KZ750-B4 (1979)
 KZ750-G1 (LTD II) (1980)
E1 13116-1007 8 x 270
 KZ1000-E1 (Shaft) (1979)
 KZ1000-E2 (Shaft) (1980)
 KZ1100-A1 (Shaft) (1981)
 KZ1100-A2 (Shaft) (1982)
 KZ1100-A3 (Shaft) (1983)
 KZ1100-D1 (Spectre) (1982)
 KZ1100-D2 (Spectre) (1983)
 KZ1100-L1 (LTD Shaft) (1983)
 KZ550-A1 (1980)
 KZ550-A2 (1981)
 KZ550-A3 (1982)
 KZ550-A4 (1983)
 KZ550-C1 (LTD) (1980)
 KZ550-C2 (LTD) (1981)
 KZ550-C3 (LTD) (1982)
 KZ550-C4 (LTD) (1983)
 KZ550-D1 (GPz) (1981)
 KZ550-H1 (GPz) (1982)
 KZ550-H2 (GPz) (1983)
 KZ650-E1 (LTD) (1980)
 KZ650-H1 (CSR) (1981)
 KZ650-H2 (CSR) (1982)
 KZ650-H3 (CSR) (1983)
 KZ700-A1 (1984)
 KZ750-E1 (1980)
 KZ750-E2 (1981)
 KZ750-E3 (1982)
 KZ750-F1 (LTD Shaft) (1983)
 KZ750-H1 (LTD) (1980)
 KZ750-H2 (LTD) (1981)
 KZ750-H3 (LTD) (1982)
 KZ750-H4 (LTD) (1983)
 KZ750-L3 (1983)
 KZ750-M1 (CSR Twin) (1982)
 KZ750-N1 (Spectre) (1982)
 KZ750-N2 (Spectre) (1983)
 KZ750-R1 (GPz) (1982)
 ZN1100-B1 (LTD Shaft) (1984)
 ZN1100-B2 (LTD Shaft) (1985)
 ZN700-A1 (LTD Shaft) (1984)
 ZN700-A2 (LTD Shaft) (1985)
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
Last edit: by gd4now.
clutch 21 Dec 2023 09:30 #892985
  • sf4t7
  • sf4t7's Avatar
Thanks gd4now, I'm not as familiar with the KZ650 so I included the info from partzilla.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
  • Page:
  • 1
  • 2
