Valve adjustment Z1/KZ 1000 22 Aug 2017 06:21 #769439
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2635
While I was in there I repaired another stripped thread.
Valve adjustment Z1/KZ 1000 14 Dec 2017 16:37 #776048
  • SWest
  • 10 22 2014
The head will have to come back off soon. :dry:
Valve adjustment Z1/KZ 1000 14 Dec 2017 20:36 #776061
  • SWest
  • 10 22 2014
I'll finish the carb sync when I get the shims in a couple days.
Valve adjustment Z1/KZ 1000 15 Dec 2017 17:21 #776102
  • SWest
  • 10 22 2014
Got the shims in one day.:woohoo:
Valve adjustment Z1/KZ 1000 16 Dec 2017 20:44 #776176
  • SWest
  • 10 22 2014
Last adjustment for #3.
Valve adjustment Z1/KZ 1000 17 Dec 2017 17:02 #776245
  • SWest
  • 10 22 2014
Putting this here. I may have found the "Damn noise." :blush:
Valve adjustment Z1/KZ 1000 07 Jun 2018 20:51 #784764
  • SWest
  • 10 22 2014
Gotta tip my valves so I checked out the other head. Looks like I can tip them and do it all at one time. B)
Valve adjustment Z1/KZ 1000 08 Jun 2018 07:01 #784779
  • SWest
  • 10 22 2014
It's been 6 months. Was hoping to get more time but no way Jose. Time to pull the head off. I have that one piece Z1 head gasket and the one that's on it now so I will have my choice without having to buy a new one. Should be able to install my HD studs and maybe cure the base gasket leak. Maybe.
Valve adjustment Z1/KZ 1000 16 Jun 2018 16:02 #785283
  • SWest
  • 10 22 2014
I'm putting this here. I 'tipped" the valves .008" as can be seen in my Bossie the Kaw thread. Here I'm bench adjusting the valves. I wound up relapping all the intake valves as well.
Valve adjustment Z1/KZ 1000 19 Jun 2018 20:26 #785481
  • SWest
  • 10 22 2014
Tried the timing a different way but decided to go with what I know. BIG difference after the APE studs. More to come in Bike Cam. B)
Valve adjustment Z1/KZ 1000 24 Aug 2018 16:05 #789701
  • SWest
  • 10 22 2014
Glad I checked them. B)
Valve adjustment Z1/KZ 1000 28 Oct 2018 16:31 #792945
  • SWest
  • 10 22 2014
Tried two ways to adjust them.
