Valve adjustment Z1/KZ 1000 16 May 2017 20:50 #762053
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2635
Started a unofficial thread on the subject. Enjoy.B)
The following user(s) said Thank You: bl_francis, Ronnie_D
Valve adjustment Z1/KZ 1000 16 May 2017 21:40 #762059
  • SWest
  • 10 22 2014
Valve adjustment Z1/KZ 1000 17 May 2017 05:25 #762065
  • SWest
  • 10 22 2014
Valve adjustment Z1/KZ 1000 19 May 2017 20:51 #762255
  • SWest
  • 10 22 2014
Dialing it in.
Valve adjustment Z1/KZ 1000 24 May 2017 07:08 #762623
  • SWest
  • 10 22 2014
It's getting hot. Summer's here.
Valve adjustment Z1/KZ 1000 24 May 2017 13:09 #762643
  • SWest
  • 10 22 2014
Now that the valves are adjusted, a carb sync is next after this.
Valve adjustment Z1/KZ 1000 24 May 2017 21:20 #762669
  • SWest
  • 10 22 2014
Just more questions.
Valve adjustment Z1/KZ 1000 25 May 2017 15:44 #762729
  • Conspiracy
  • Conspiracy's Avatar
  • Thank you received: 18
Thanks for posting. I'll be watching.
Novice rider
1976 KZ900
The following user(s) said Thank You: GPz550D1, SWest
Valve adjustment Z1/KZ 1000 29 May 2017 14:59 #763042
  • SWest
  • 10 22 2014
Looking for the chattering noise. Used my mallet against the cam to record where the noises come from. Cam chain is a little noisy too. I'll adjust it this evening when it gets cooler. 105 today.
Last edit: by SWest. Reason: sp
Valve adjustment Z1/KZ 1000 29 May 2017 21:12 #763068
  • SWest
  • 10 22 2014
Sounds better.
Valve adjustment Z1/KZ 1000 31 May 2017 17:46 #763199
  • SWest
  • 10 22 2014
I think I've narrowed it down to cam bearings. Have some on the way.
Valve adjustment Z1/KZ 1000 01 Jun 2017 07:35 #763235
  • SWest
  • 10 22 2014
I'll have to edit the clips and repost it on youtube. Meanwhile here's what I got.
